Windows 7: very strange problem with acpi battery control method
01 Dec 2011   #1
cobe
windows 7 ultimate x64
i have a sony vaio vpceb 190x with a windows 7 ultimate.after instaling VAIO control centar i get a message that the battery is not compatible ,press ok to hibernate....
If i disable the acpi control method in device menager i dont get the error mesage but the computer does not have control over the battery.its like it dosent exist.
Ive tryed with a diffrent windows instalation.but the problem is still there.
Icant change anything in BIOS PM settings,
Can anyone help me?
02 Dec 2011   #2
CreepinJesus
Try uninstalling the Vaio Control Centre. That should let Windows handle the battery.
02 Dec 2011   #3
AllOnTheBus
Windows 7 Home Premium 64 Bit OS
I agree- this is bloatware that you really don't need.
You can control power options through Windows as Creepin has mentioned.
If you want to tweak those settings you can click on the power icon in
the system tray/ notification area of the taskbar-> more power options
->choose your power plan as required->Change plan settings->change advanced power settings
In here you can change what your machine does for hibernate on battery and on power etc etc....
If you don't want to fully remove the VAIO Control Center the following link will show
you how to disable the battery care function - I think this what you are after.
Link: http://digitalpbk.com/hardware/sony-...e-battery-life
Hope this helps- cheers
02 Dec 2011   #4
cobe
i've tried uninstaling Vaio control centar but the problem is still there.I have to format the parition and instal a fresh copy of windows.
I need Vaio control centar for the shortcut keys on the laptop and HDMI conection.Without control centar the HDMI does not work properly.
02 Dec 2011   #5
cobe
I ll try what AllOnTheBus sugested and get back to you
Thank you for sugestion
02 Dec 2011   #6
AllOnTheBus
Yes ty
Please post back results which may assist future visitors to this forum
02 Dec 2011   #7
cobe
NO luck.the control cenatar was missing the battery option as shon on the picture.Here s a print screen
Any other suggestions ?
02 Dec 2011   #8
AllOnTheBus
Could be a problem with the software itself then.
Take note of where the error is occuring and use the
advice they are telling in regard to looking
at the electronic manual for your product. See if there are any troubleshooting
tips and/ or guides on the operation of that software.
Otherwise- as Creepin said you may want to uninstall the software.
As I previously mentioned you can do all sorts of settings for the battery
using Windows itself, however you would be able to uninstall and reinstall
a "fresh" version of your software if you so please.
If that's what you decide to do, then look for the serial/ model numbers and any other
indicators of your particular model and then Google around to find the .exe file
to download and reinstall and the instructions for the safe uninstall and reinstall.
The Sony support site for your country/ region would be
a very good place to start and I would recommend getting the .exe file from there
and NOT a third party.
Good luck
Note: Do not install the software from the following link as it is a Vista download, I
have only provided this link AS AN EXAMPLE of the sort of informational page you will need to search for!!!!!
http://esupport.sony.com/US/perl/swu...=4794&os_id=27
Microsoft ACPI Compliant Control Method Battery is MISSING
As the title says , Microsoft ACPI Compliant Control Method Battery is missing.. I can't find it in the device manager... i tried restarting my laptop a couple of times but nothing changed... this just happened a while ago ... i tried searching for the driver over the internet .. but I can't find...
Drivers
Reinstall driver "Microsoft ACPI Compliant Control Method Battery"
Hello all, I've spent a good few days trying everything the internet has thrown up to fix my mistake but nothing has worked. I shall list my attempts to fix subsequently. My problem is this: six days ago, I was using my laptop on its battery and I noticed that the battery icon in the...
Drivers
Microsoft ACPI-Compliant Control Method Battery DISABLED
Hi! I have disabled the "Microsoft ACPI-Compliant Control Method Battery" in the Batteries section of the Device Manager on my Windows 7 computer. I have done this in order to lower the latency as am working on audio production. I have lost the Batterly level indicator icon but I don't care...
Hardware & Devices
Microsoft ACPI Compliant Control Method Battery is gone!
When I check my device manager, Microsoft ACPI Compliant Control Method Battery is missing, thus the battery bar on the bottom is also gone, and the box for enabling the battery bar is greyed out. Somebody Please Help me!
Drivers
Strange Battery issue...looks Windows 7's Acpi
Hi there, since this morning i don't have anymore the icone & power management for my battery. The battery works fine when i unplug and let it for an hour, charging when plugin back. I looked everywhere and all seems correct. In Device Manager i uninstalled the Battery drivers, then rebooted...
Hardware & Devices
Microsoft ACPI Compliant Control Method Battery - Not doing much!
A couple of weeks ago my laptop decided to start displaying a red cross over the battery icon, there is also a warning message saying something along the lines of (I use a Japanese version of Windows so I am translating so might not be exactly what it says in the English version) "Due to a problem...
Drivers
