Classpnp problem on Win 7 64bit, even after fresh OS installation.
  1. Posts : 49
    Windows 7 32-Bit Professional
    Hi
    The laptop was initally ok, but I slammed it shut too hard and broke the screen. I replaced the screen and I was then having startup problems on Win 7 and when attempting to login in safe mode it hanged at 'classpnp'. I did some research, but as I wasn't even able to get to a command prompt i decided to carry out a disc clean using DISKPART and re-installed the OS, only this time I firstly installed XP and then Win 7 for a dual boot system. I fully formatted the HDD removing all original partitions (including the recovery partition, and I do not have recovery discs)
    It worked ok for a few hours and then the Win 7 OS started slowing down badly. XP boots fine, but i am now again unable to start Win 7. Startup repair does not work also. I was not able to install my drivers. Like I say, XP is fine.
    My laptop is an Asus X5DIJ 4GM RAM/Intel Pentium Dual Processor 250GB HDD
    Many thanks in advance.
  2. Posts : 1,814
    XP / Win7 x64 Pro
    If you don't have a recovery disk, how did you reinstall Win7 and/or XP?
  3. Posts : 49
    I used an official copy of XP I have on disc and my brothers Win 7 disc.
  4. Posts : 1,814
    XP / Win7 x64 Pro
    Is the Win7 disc a genuine copy as well or is it something that was torrented/downloaded?
  5. Posts : 5,642
    Windows 10 Pro (x64)
    Sounds to me you broke more then just the screen...dunno what without more information like what is classpnp loading when it hangs.
  6. Posts : 49
    No it's not a genuine 7 disc :-( (Please note I do not use torrents) He used it to re-install on his laptop as his was OEM installed, and thought it would be ok, he's not had any problems with his....
  7. Posts : 1,814
    XP / Win7 x64 Pro
    Well, first of all, you can't install an OS on two separate machines and have them validate with MS. So, you'll need to purchase a license to use Win7. Second, not knowing where the disc came from, we can't speculate on what issues it might or might not cause, just as a mechanic can't speculate on what happened to your car when you took it to a different and unknown mechanic.
    If XP is working without such issues, I doubt you have a hardware problem on the laptop, but I suppose it's still possible. I'd continue to use XP since that's working fine until you can purchase a valid copy of Win7. If you have problems installing that, we'll be here to help.
  8. Posts : 49
    Sure, I understand, but I have a valid licence for Win 7 that came with the laptop. the XP is fine. I validated my Win 7 using my COA key from the base of the laptop and it was validated fine. I merely used the 7 disc purely to install the OS, using my Licence key that came with my laptop when I purchsed it. It seems unfair to have to buy another copy of Win 7 when I have the OEM version that came with my laptop, but was lost when the laptop had issues....
  9. Posts : 1,814
    XP / Win7 x64 Pro
    Ah, I see. I made an incorrect assumption that because you didn't use a genuine CD that you didn't have a license. I apologize for that. However, we still can't help you out if you haven't used a genuine CD from Microsoft. The good news is that you can easily download a genuine ISO from Digital River, Microsoft's partner in offering Windows 7 ISO's:
    Official Windows 7 SP1 ISO from Digital River « My Digital Life
    I'd recommend you download the appropriate genuine ISO, burn it to CD, reinstall Win7 and see how things go from there.
  10. Posts : 49
    No problem! Brilliant, I shall download as instructed, and report back. Many thanks.
