Difference between W7 Home premium & Ultimate 64 bit.
  1. Posts : 25
    Windows 7 Home Premium 32bit.
    Hello there,
    I'm really new to the whole computer stuff, I was wondering what's the difference between those too? Also which one's better? Cause I currently have the W7 Ultimate 64 bit disk. But I currently have W7 home premium installed.
    Which ones better?
    Thanks!
  2. Posts : 72,052
    Hello Dawn,
    It's really not a matter of which one is better, but instead which one has the features that you need or want included in it or not. Saying that, Ultimate has all features included where Home Premium doesn't. The link below can help you compare what features are included in each of these editions to help you decide which one is better for you. :)
    Compare Windows 7 Editions
  3. Posts : 25
    Thanks for the very quick reply, I appreciate the help.
    Oh and I forgot to add, If I want to install It to my computer what will I have to do? Just Insert the disk? And restart It?
    Thank you!
  4. Posts : 72,052
    You're most welcome Dawn. If you have any other questions about this, then please let us know. :)
  5. Posts : 25
    If I want to install It, Will I have to just insert the disk? And wait for an installation yo popup?
  6. Posts : 5,795
    Microsoft puts up a chart that's easy to find and use:
    Compare Windows - Microsoft Windows
    There is no better version. It's what version fits your needs. If there's no additional benefit to you to run Ultimate, don't bother.
  7. Posts : 5,642
    Windows 10 Pro (x64)
    Do you actually need Ultimate? But yes...you just install it like you would any other Windows OS...
  8. Posts : 72,052
    ChubbyDawn said:
    If I want to install It, Will I have to just insert the disk? And wait for an installation to popup?
    If you are getting a retail copy of Windows 7, then you could boot from the installation disc to install it. The tutorial below can help give you a detailed step by step on this to give a feel on how to.
    Clean Install Windows 7
  9. Posts : 25
    Never mind I wont Install It, It look's too complicated.
    I appreciate all of your help, Thanks guys!
    * Marked as solved. *
  10. Posts : 13,576
    It`s not complicated at all, my advice to you is do a lot of research b4 you even attempt anything with your pc. So many people are coming here and say I did this or I did that and now my pc won`t start. If it`s running fine then don`t mess with it, just use it. There is excellent help here and many tutorials on how to do different things. I am a tech and I still learn new things everyday.
