Hey everyone,
Im having a problem with my fonts, i was installing around 10,000 new fonts directly into the font directory. everything was going fine and the fonts finished installing, however the top progress bar stayed on, but didnt move for about 10 minutes, so i force closed the window.
after restarting the computer, my fonts folder says 0 items, and there is NOTHING in the list. If i go into any program, it says my fonts are hidden, however i have found no way to unhide them. I have checked the font settings and removed the hidden options but still nothing.
The font folder size is around 450 MB, so i know the fonts are in there, they just dont show up.
Anyone know how to fix this? or at the very least get it back to system default, as this would probably be the best idea.
I tried searching around for a solution, but couldnt find anything.
windows 7
- windows 7
