Newly build PC hard drive problem
  1. Posts : 93
    Windows 7 64-bit
    Hello Guys&Girls
    I've recently built a new system with 2x2TB drives, one with my OS on and one with my Music etc on..
    When i power on the machine, it starts to boot up, then throws an error message, instantly, then instantly reboots so i am unable to view it, and then it boots straight into windows, it's as if its trying to boot from the wrong hard drive.
    I then installed Partition manager, to look at my drives, and this is what i got.
    I thought maybe this is the problem, as disk 1 is not my C:
    Any help please?
    Thankyou
  2. Posts : 93
    Windows 7 64-bit
  3. Posts : 4,466
    Windows 10 Education 64 bit
    According to your screen shoot, Disk 1 has the system reserved partition, but your OS is installed to disk 2. Normally they would both be on the same drive.
    What does disk management show?
    What drive is set to boot from in the BIOS?
  4. Posts : 93
    Windows 7 64-bit
    The hard drives are called the same thing :/ as they are 2 of the same drive and capacity
  5. Posts : 1,533
    Unplug all drives except your boot drive (the one that Windows is installed on) and run startup Repair 3 times as demonstrated in this tutorial: Startup Repair - Run 3 Separate Times
  6. Posts : 93
    Windows 7 64-bit
    Am i miss-understanding this start up repair thing wrong? But there is only one Operating System?
  7. Posts : 613
    Yes only one operating system resides but was installed on disk 2 instead of disk 1 but the 100MB reservered partition which is installed with W7 will always be on the first partition of the first drive and contains data for bitlocker and startup repair should you need it.
    Please follow windude99s instructions.
  8. Posts : 93
    Windows 7 64-bit
    Would doing the startup repair, change my c: to disk 1 instead of 2?
  9. Posts : 290
    Windude99's instructions are what you need to do, there will only be Disk 1 until you plug in the other drive after startup repair fixes your problem.
    In the future, when installing W7, only have one drive run running on your machine!
    Connect your other drives after the install.
  10. Posts : 26,869
    Windows 11 Pro
    The 100MB System Reserve is what Windows boots from.It then hands it off to your Windows OS partition, drive "C". They need to both reside on the same disk, Disk 0 (or 1 if you want). At the present time the system reserved is on one disk and your C drive is on the other. What Windude99 is trying to do is force Windows to write the system reserved partition to the correct disk. You can then delete the wrong system reserved partition, and you should have no problems booting then. As Windude asked, disconnect the drive with the current system reserved partition and run startup repair 3 times with attempted boots in between each time. Or if you would rather, connect the correct disk only, and do a clean install.
