My laptop running on BATTERY and giving error 'No battery detected'
eaglehdr
my battery was giving 1.5 hour power backup from last 4 months... then last month it decreased to 1 hour...from couple of days it decreased to 1/5 hour(with error 'Consider replacing new battery') and yesterday i was using on battery power... and battery had 34% power remaining.. suddenly battery indicating light turns orange and pc shutdown... after that.. my pc is not charging battery... and if i run pc on battery.. it work 10 to 15 minutes ( with orange light.. and on task bar.. battery icon giving error "No battery is detected" ) and then shut down.
today i run laptop on battery power and open setup..and there was error "No battery installed" in battery info...
what happened.. can anyone tell me????
i forgot to tell you that... according to battery's LEDs.... my battery is healthy enough.. but now only 1 led is working...
dell d620
window 7 ultimate 32-bit
intel core2 duo
8mb
sigmatel
lcd lid
80gb
Your battery has failed and must be replaced. They're only good for three or four years. Happens to all laptops.
Self-built
Ubuntu Lunix and Windows 7
Intel Core2Quad QX9700
Gigabyte GA-EP45-UD3P
8 GB Corsair Twin-X
Sapphire/ATI Radeon HD5850
Embedded or Bose Companion System V
Apple 23 Inch Cinema Display
1920 X 1200
1 X 120GB Intel Series 320 SSD
2 X 1TB Western Digital WD1002 FAEX internal hard drives
1 X 1Tb Seagate 7200.11 SATA (external, for backup)
Corsair 750TX
Lian-Li V2120B
Zalman CNPS ZX10C
CVT Avant Prime
Logitech wireless trackman
Comcast 8M/sec
Also use MacBookPro (1st gen Intel w/ OS X 10.6) and a second desktop built upon an Intel D975XBX with Intel E6600 multi-booting Ubuntu, SuSE and Fedora Linux and 32-bit Windows 7 Home Premium..
Thanks for advice, now i realize that i have to buy new one. :cry:
dell d620
intel core2 duo
8mb
sigmatel
lcd lid
80gb
