Help with determining the registry entry/process causing my problems
  1. Posts : 3
    windows 7 prefessional 64 bit
    My os is windows 7 professional 64 bit and have been using the computer for about a year with no problems until now. I am having problems with several programs, and I suspect that because I started having problems at the same time it is either the registry a process is causing the problems. For the 3 programs below I have tried to reinstall the programs, do in place repairs, and I did a repair install of windows 7, with nothing getting fixed. So, I am at a loss as to what to do next, short of doing a clean install (which I would prefer not to do).
    So, if anyone can help me I would gratefully appreciate it.
    The programs that are not working properly are outlook 2003 (it crashes when I try to open the calendar),
    the event viewer log says:
    Event id: 1000
    Faulting application name: OUTLOOK.EXE, version: 11.0.8326.0, time stamp: 0x4c1c2372
    Faulting module name: unknown, version: 0.0.0.0, time stamp: 0x00000000
    Exception code: 0xc000041d
    Fault offset: 0x733f4f0d
    Faulting process id: 0x430
    Faulting application start time: 0x01cdac7e019f4e22
    Faulting application path: C:\Program Files (x86)\Microsoft Office\OFFICE11\OUTLOOK.EXE
    Faulting module path: unknown
    Report Id: 723dbf28-1878-11e2-a676-485b39a3402d
    Paperport 11 (thumbnails on multipage documents does not display)
    The event viewer log says:
    Event Id: 1000
    Faulting application name: PaprPort.exe, version: 11.2.0.333, time stamp: 0x489af374
    Faulting module name: tvctrl.dll, version: 11.2.0.333, time stamp: 0x48750d8f
    Exception code: 0xc0000005
    Fault offset: 0x00004f15
    Faulting process id: 0x10ec
    Faulting application start time: 0x01cdac73ccf04b07
    Faulting application path: C:\Program Files (x86)\ScanSoft\PaperPort\PaprPort.exe
    Faulting module path: C:\Program Files (x86)\ScanSoft\PaperPort\tvctrl.dll
    Report Id: 181ac19c-1867-11e2-a681-485b39a3402d
    And msn internet explorer, which crashes upon opening.
    Event Id: 1000
    Faulting application name: msn.exe, version: 10.20.91.1100, time stamp: 0x4e1bccfb
    Fault offset: 0x73154f0d
    Faulting process id: 0xc90
    Faulting application start time: 0x01cdac73df466352
    Faulting application path: C:\Program Files (x86)\MSN\MSNCoreFiles\msn.exe
    Report Id: 26decad0-1867-11e2-a681-485b39a3402d
    Thank you in advance for the help anyone can offer.
  2. Posts : 3
    Just to add the other things I tried but did not mention (as best I remember):
    selective startup: no changes
    Safe mode: no changes
    trying to repair outlook, I tried:
    safe startup
    detect and repair
    scan pst tool
    outlook /cleanreminders, outlook /resetfolders
    Thanks for any assistance
  3. Posts : 3
    also:
    a system restore to before the problem started
    and a malware/virus scan
    again to no effect.
