Problem on changing Default Copy Handler
Page 1 of 3 123 LastLast
  1. Posts : 130
    Windows 7, 64Bit
    Hello,
    I have been using TeraCopy as my DCH in the past two years,
    But since i made my customized desktop & installed it won't become my DCH
    even though the settings is to make it DCH, i have installed other Copy Handlers
    but all of them came with the same issue that they won't become DCH,
    clearly the problem is in my PC/Windows, Please tell me if any one knows how to fix this?
    Specially that i have a lot to Copy & Move files to do, because of my line
    of work & i am really sick of windows DCH.
  2. Posts : 6,285
    Windows 10 Pro X64
    What do you mean by since i made my customized desktop?
    What happens if you remove the customization?
  3. Posts : 130
    Windows 7, 64Bit
    Not that, i meant i made a custom Desktop PC:-
    Thermaltake Case, Asus MotherBoard ...etc
  4. Posts : 6,285
    Windows 10 Pro X64
    So Teracopy is setup like this?
  5. Posts : 130
    Windows 7, 64Bit
    Exactly, See the picture:-
    The only thing i think that will work in this case
    is to set the DCH value in the Registry to =0!!!!
    But i don't know how nor if it possible/will it work?
    Attached Thumbnails Attached Thumbnails Problem on changing Default Copy Handler-3.png
  6. Posts : 6,285
    Windows 10 Pro X64
    I searched the registry for teracopy and found lots of locations but none that seemed to have anything to do with DCH (default copy handler). Do you know what key that is?
    Hmmm, just noticed TeraCopy does not get used for me either when I drag and drop files, at least I don't see the TeraCopy window pop up.
  7. Posts : 130
    Windows 7, 64Bit
    Actually i don't really remember about Drag-n-Drop,
    because usually i copy/move files that is larger than 1GB
    between HardDisks, & in my laptop TeraCopy was the manager!
  8. Posts : 6,285
    Windows 10 Pro X64
    Ah, just tried a large file between two drives and TeraCopy handled it, so it is working for me.
  9. Posts : 130
    Windows 7, 64Bit
    Does any one knows why is this problem happening to me?
  10. Posts : 6,285
    Windows 10 Pro X64
    Try creating a new user account and set TeraCopy as the DCH there maybe, see if that makes a difference?
