Windows 7: Bold font problem in programs (Not the average problem)
07 Dec 2012   #1
awkook
Windows 7 Pro x64
This isn't your average bold font / italics problem. This problem doesn't occur in windows folders or anything, it happens in only a few programs. It happens in Ventrilo (http://i.imgur.com/u6e00.jpg) and it happens in Sony Vegas which cuts off my window (http://i.imgur.com/oDFdc.jpg) .
You may notice that if you've ever used those programs, the fonts aren't bold like that. My DPI is at 100%, I've tried re-installing my fonts, setting the default settings, and it doesn't change with themes. I want to avoid re-installing windows, and if that's the only option, I guess I'm just gonna have to live with it. Any help would be appreciated! Thanks!
20 Jun 2013   #2
manager00104
Quote   Quote: Originally Posted by awkook View Post
Hi I also have the same problem if anyone could help with this it would be great cause in the main set of options I can only see "BOLDED" areas in drop down options every where GUI display panels etc ...
19 Jun 2014   #3
awkook
Windows 7 Pro x64
Bumping this because i still have this problem
20 Jun 2014   #4
mitchell65
Looks like the problem is with your actual programs not with Windows. Where did you get your copies of the programs that are causing problems especially Sony Vegas?
Windows 7 bold font by default problem - solved
in case anyone is still having problems with having a bold font appearing everywhere after restart that is not fixed by reseting themes here is what I've come up with. After an hour of ripping my hair out I finally narrowed it down to a very simple thing "C:\Windows\Fonts" folder was missing...
Customization
Bold font only in some programs
So my Windows looks absolutely normal, except in SOME programs I have a bold font problem that I can't get rid of. I've seem to have tried all the fixes that other people have posted on the web but I cannot fix this. Programs like Ventrilo have this problem, but no where in Windows does this...
Customization
Problem with Arial Bold Font
I am being driven to distraction by this. Every time I boot Windows (64-bit ultimate), there is a problem with Arial Bold. It displays in all programs as the bold italic version. When i went into Control Panel > Fonts, it showed it wasn't installed, but when i downloaded and tried to install it, I...
General Discussion
Bold font in programs
Hi I have a very big problem. All fonts in programs are bold and someone are italics. Anyone who know how I fix this problem. Before 3 days I haven't this problem, but I don't know what's happening... HELP:cry::cry:
General Discussion
System uses bold font
Hello, I don't know when the problem occurs but my font looks really ugly in some places... for example in the delete dialog: http://i48.tinypic.com/dz7zp5.jpg Or in Firefox tabs and the 'Browse' dialog... How to change this ugly thing back to windows default?
Customization
Not your average sleep problem
Hey I have Windows 7 x86 RC on an older HP dx6100 (Pentium 4 3.2Ghz). The current problem is it ignores its sleep setting (Never) and puts itself to sleep all the time. I've changed the profiles to High Performance, back to Balanced, changed the profile myself and saved all the settings,...
General Discussion
