Perplexing problem--disappearing place to click
  1. Posts : 1,606
    Windows `10 Professional 64bit
    Hi all. This is a tough one to explain and if this is the wrong place to post, let me know.
    Here goes--I built a new Windows 7 computer last Saturday (January 5). Here's what happens.
    Lets say I am telling Windows 7 to empty the Recycle bin. I "empty the recycle bin" and nothing seems to happen. If I drop the recycle bin window, I see the message "are you sure you want to delete these files".
    I am seeing so much of this kind of stuff. I hope I have explained this properly.
    I built my first Windows 7 computer last May and have not seen anything like this.
    I am at your mercy because I don't have a clue.
    Any thoughts?
    Thanks for reading this.
  2. Posts : 2,014
    Windows 7 Professional 64bit
    Hi Jadinolf,
    I think a good place to start would be to check your system file intergity.
    To Perform a System File Check:
    Click on the start button> Type CMD on Search
    Right click CMD and Run as Administrator
    Type: SFC /scannow at the prompt
    Full tutorial here:
    Let that run and reboot and post back status
    Cheers
    Dave
  3. Posts : 1,606
    Thanks Dave. I'll give it a try.
    Have never run sfc on Win 7
  4. Posts : 1,606
    Ran sfc. No integrity violations found.
    Back to the drawing board.
  5. Posts : 2,014
    Hey Jadinolf,
    Thats good that no integrity violations were found :)
    Ok..this is a solution you may try to resolve the recycle bin issue (as i dont know your other issues?):
    IMPORTANT: The following procedure permanently deletes all files and folders which are already in the Recycle Bin (from all user accounts in the system) and cannot be recovered.
    1. Same as before:
    2. Type the following command and press ENTER:
    rd /s /q C:\$Recycle.bin (just copy and paste this as its easier)
    This will clear out the $Recycle.bin folder from the C:\ partition. If you have more than one partition you might have to do this for each hard drive partition in your system.)
    Type exit to close the Command Prompt window.
    Reboot and check recylce bin operation
    If that does not do the trick, you can try Ccleaner, which incudes that very function.
    http://www.piriform.com/ccleaner/builds
    Give that a try and let me know.
    You may also want to check what programs are running in the backgound and uninstall any you never use:
    http://windows.microsoft.com/en-GB/w...er-performance
    Cheers
    Dave
  6. Posts : 1,606
    OK, Dave. Thanks.
    I'm tied up with another problem on another computer but I'll get to this.
    Stand by.:)
  7. Posts : 1,606
    Well, the problem seems to have disappeared.
    Can't believe it solved itself but it's working properly.
    Thanks all.
  8. Posts : 2,014
    Thanks all.
    Hey no problem,
    Maybes something you did managed to resolve it, or maybe a glitch...who knows.
    Glad your sorted, can mark this thread solved please. And feel free to pop back anytime if you have any more queries or questions.
    Cheers
    Dave
  9. Posts : 1,606
    Thanks all.
    Hey no problem,
    Cheers
    Dave
    Oh I will pop in - that's for sure.
    I have tried duplicating the problem several times this morning. Won't do it.
  10. Posts : 2,014
    Thanks all.
    Hey no problem,
    Cheers
    Dave
    Hmmm, maybe the SFC worked
    Anyway enjoy
    Cheers Dave
