Bringing pc to same memory state after crash or power cut. Best way.
JohnAtanasoff
10:50 PM
Hi, i looked this over on google and did not find the info i want.
Basically on a mac laptop when the battery runs out and then you turn on the laptop again it preserves its state from last time; i dont remmemer a crash on a mac OS so i cannot speak for it.
In windows 7 is there a built in tool for the same, apart from "Backup and restore" so we can bring it to the exact same state with the same files open etc?
Please also mention some good 3rd party tools you know for this effect.
Cheers
Windows 7 Ultimate x64i7 3770K16GBP8Z77-V PRO/THUNDERBOLT builtin Graphics Card
i7 3770K
ASUSTeK COMPUTER INC. P8Z77-V PRO/THUNDERBOLT
16GB
OCZ vertex 4
western digital black caviar 1tb
avast
ff, chrome
Welcome to the Seven Forums.
The feature that you are looking for is called hibernate. It will only be available if the video drivers support it.
W7 Pro SP1 64bit
i7
8GB
Intel HD Graphics
crappy SSD
Thanks UsernameIssues,
Hibernate works perfect when you want the machine powered off then bringing it back with everything as you left it. I have just enabled it and You have just saved me time with this tip.
I wonder if hibernate when not invoked will work after a power cut?
Also I'm getting bsod's followed by a memory dump quite often or when invoking certain SW. Its very annoying when involuntarily i loose my unsaved files and tasks i was doing.
Do you or anyone happens to know an app that will bring pc to same memory state after this happens?
i7 3770K
16GB
OCZ vertex 4
avast
ff, chrome
If there was a power cut, there should still be enough battery power to put the laptop into hibernation.
If the computer is crashing with bsod, then you will lose unsaved info.
You should make a new thread here: BSOD Help and Support - Windows 7 Help Forums
W7 Pro SP1 64bit
i7
8GB
Intel HD Graphics
crappy SSD
i7 3770K
16GB
OCZ vertex 4
avast
ff, chrome
