Windows 7: Problem starting up after using samsing recovery basic recovery
11 Jun 2013   #1
Laurina
After using samsung recovery, my computer won' t start properly. In normal mode it crashes immediately after loadin my background and desktop items. It shows a blue screen ( see image) and then will restart itself, giving me the option to start windows normally or in safe mode. I have tried safe mode, and that works slightly better. It doesn't crash all by itself before I even do anything. But it also won't open most programs properly ( like windows explorer). So I can't actually do something in safe mode. After I open a more advanced program ( like Chrome) it will crash again the same way as before. Can someone help me wih this?
P.S.: I am wriing this on my mobile phone, so please forgive me for any typos.
https://docs.google.com/file/d/OByQW...it?usp=sharing
11 Jun 2013   #2
VistaKing
Windows 7 Ultimate 32-Bit & Windows 7 Ultimate 64-Bit
Hi Laurina welcome to SevenForums
Try this tutorial below
Troubleshooting Windows 7 Failure to Boot
Startup Repair
Dynamic to Basic Disk Conversion to do recovery (have bad registries)
Hay there, I use HP Probook 4530s with Windows 7 64-bit Home Premium x86. I installed the HP Protect Tools, but it made my registry bad and I am unable to delete them. As a result my laptop is slow now and takes a lot of time on Welcome screen when powered on. So, I needed to do recovery...
General Discussion
Can I install Windows 7 Home Basic from Recovery Disc again?
I have DELL Inspiron 3420 (laptop). When I purchased my laptop, a genuine "Windows 7 Home Basic" (64bit), was installed in it. But this windows was so heavy and slow. I made recovery discs of Windows 7 Home Basic. Then I uninstalled Windows 7 Home Basic and installed a fresh copy of "windows 8...
Installation & Setup
Win 7 not starting after system image recovery
Replaced my HD and used my Win Image BU, but Win will not start. I get the Dell screen that says Windows is loading, but then it is a blank screen. I did a second restore with same outcome. I followed http://www.sevenforums.com/tutorials/675-system-image-recovery.html exactly, but cannot get...
Backup and Restore
Use Home basic recovery dvd to install ultimate.
By editing the ei.cfg we can install any version of windows in stranded dvds. Is there any way to switch editions in recovery dvds? I have Dell's Home Basic recovery dvds, is it possible to edit something in it and install ultimate or professional ?
Basic Bootable partition/Recovery mode?
Hi. I am using WS2008 however the procedure is the same as Win7. What I want to do, is have the ability to install, on a partition, a bootable partition where it will allow me to install Windows from a directory which contains the entire contents of the DVD/ISO which is on location on another...
Problem w/ creating recovery disc in Recovery Manager
I am running windows 7 on my laptop. I has windows vista before the upgrade. I had recovery discs for windows vista created from the recovery manager. I tried to make discs for windows 7. I would like to know why it won't let me make a disc for windows 7 because if I had trouble and needed to put...
Performance & Maintenance
