Cannot load Welcome screen. Someone messed with my registry.
  1. Posts : 5
    Primary: Windows 7 Home Premium 32-bit Secondary: Windows 7 Professional 32-bit
    Hi. I have a problem. As the thread title indicates, my laptop cannot get to the Welcome Screen. Windows Repair loads fine, and I am able to do minor editing tasks there. I have had this as an issue for a while now, and I just figured out that the laptop in question, a Dell Latitude D531, has had the Registry tampered with. Firstly, the permissions on several Registry items were screwed up horribly. That has been fixed thanks to SubInACL and this guide here, but it still won't load the Welcome screen. My registry backup (HKLM/Software) is at my Skydrive here.
    The backup was performed in Windows Repair mode (Press F8 at BIOS, Repair Windows, Command Prompt, regedit) after the permissions were fixed. Any help is appreciated.
  2. Posts : 1,007
    Winndows 7 32 bit
    Hi MC4444,
    Please check this link below which should help you resolve this issue:
    Troubleshooting Windows 7 Failure to Boot
    Keep us posted with the results so we can advise you further.
  3. Posts : 5
    Obviously I did not explain my problem well enough. It isn't a Bootable Flag problem, nor do I have any System Restore points, because I had gotten the laptop on the day before the incident. This was a refurbished computer, so I have no System Repair DVD.
    I have a setup on the laptop I'm currently using that lets me open a Command Prompt anywhere, and change the active directory to the one I selected the option from. When my newer laptop was gotten, it did not have this setup. So I asked a friend (who obviously had very little experience with Windows 7, only XP) to "tweak" it for me. It was working fine afterward, but the option, when selected, only opened a Command Prompt window in the %WINDIR% directory.
    At first, I thought it was because I hadn't logged off since the "tweak" was finished that it wasn't working properly. I was wrong. He botched the job, and screwed my Registry up in the process. My laptop loads Windows, gets to a blue background screen with the mouse cursor in the center (which responds to mouse movement, oddly enough), then does nothing more. It just sits there. It never loads the actual Welcome screen.
    I was hoping someone would look at the .reg file I linked to first, so they could see if anything was wrong with my registry. Instead, I'm being linked to tutorials. I already know it is a Registry-only issue. I deleted the "Open Command window here" option out of the Registry through Windows Repair, so that is why it isn't in the .reg file.
    If you have any questions, please don't hesitate to ask.
    P.S.: The System Repair option in the System Repair menu detects nothing wrong with my computer.
  4. Posts : 25,847
    You are probably correct MC4444.
    This Forum probable doesn't have any Tutorials that correct the registry changes a XP expert has done to Windows 7 registry.
    Well maybe one or two Tutorials.
    Clean Install Windows 7
    Clean Reinstall - Factory OEM Windows 7
  5. Posts : 1,711
    Win 7 Pro 64-bit 7601
    afaik, this won't happen. Too much stuff that only MS knows what is in there (and does not bother telling nor troubleshooting), not even our MVP can do it.
    Look in the \windows\system32\config\regback folder. It should contain automated registry backups that you can restore (copy to windows32/system/config), but given how new that installation is I don't know if there are any.
    You can run sfc scannow, but I doubt it will fix registry.
    Otherwise what Ladyback Bear posted is the only thing you can do to fix it. Besides, a clean install should get rid of crapware installed by the manufactuter and leave a more performing PC.
    To keep your spirits up, I can tell you something you might like.
    What you wanted to do with the friend's registry edit is mostly already there in windows 7 (and vista).
    Shift+rightclick, select "open a command window here" from the menu and it opens a command prompt already located inside the folder. (so that you don't have to cd your way to it).
    And with a tiny and easy registry hack you can do yourself without risk, you can have that always visible at rightclick (so you don't need to press Shift).
    I have it that way on my PC too.
  6. Posts : 1,007
    Winndows 7 32 bit
    Hi MC4444,
    Thanks for providing us this information. As correctly suggested by Layback Bear you should attempt clean installation on the system as you have recently got this system so you would not have alot of data on it.
    I am assuming this system would have come with OEM product key sticker on it. You can download your version of Windows 7 from the link below:
    Windows 7 Direct Download Links
    And, create a bootable USB drive and install windows from the link below:
    Windows 7 USB/DVD Download Tool
    Hope it helps.
  7. Posts : 5
    Bobafetthotmail, there is a regback directory with registry hive files in it. Will any updates still work after I import them?
    SandeepP - It is refurbished, and I cannot find an X17-43423.iso file anywhere. I have the paperwork with my Product Key. Will any Win7 Professional 32-bit DVD image work? Also, Microsoft Office Basic 2007 is installed on it. Will I lose that?
  8. Posts : 1,711
    Not the ones installed after the last backup. At most you will have to re-download or reinstall them as if it never happened.
    Will any Windows 7 Professional 32-bit DVD image work
    Yes. Just need the product key. Will activate a 64-bit version as well unless on the sticker it specifies that it is 32-bit only. Both SandeeP the Dell guy and Ladyback Bear posted links to the page where you can download clean and legal windows 7 ISO files you can burn to a DVD or whatever.
    You need to look for X17-59183.iso for the Pro 32-bit and X17-59186.iso for the Pro 64-bit. Those iso files contain SP1 and all updates up to may 2011 (MS did that, it's not slipsteamed).
    Yes. All programs will be lost if you reinstall. In case you don't have the license key written down (usually the case of OEM installs), you must extract the license key of it before reinstalling, connect the hard drive to a working PC and follow this tutorial. Then you need to get the install media for it, which is available here. (after you have the license key)
  9. Posts : 1,007
    Winndows 7 32 bit
    Hi MC4444,
    Yes you can download and install Windows 7 from .iso file and use the product key on the system to activate windows.
    Also, for all the premium software that are been purchased along with the system you can check the link below for downloading the same:
    http://dell.to/13Xh9yG
    If you have any further queries, please feel free to contact us.
  10. Posts : 25,847
