Computer *Jet Engine Sound* *Using Too Much Memory*
  1. Posts : 4
    Windows 7 Ultimate 32 Bit
    My computer has started to sound like a jet engine when it starts consuming memory almost all of it with only google chrome open right now its consuming 1.12gb when i turn it on it sounds like a jet engine and when i play ang games even halo and it starts consuming memory it starts making that terrible sound.
    https://www.dropbox.com/sh/92bzcs9n29c398j/1JVSkYoEpD
    Some images of the task manager
  2. Posts : 30
    Windows 7 Ultimate 64 bit
    Well the memory and cpu usage seems fine, Um. Have you tried cleaning out any dust? or making sure the computer isn't heating up? I know the fan on my laptop doesn't kick up the power until I accidentally block the fan.
  3. Posts : 4
    Might be heating up . how do i check to see if it is? and no i have not tryed cleaning any dust .
  4. Posts : 30
    Well if it sounds like the jet engine feel around, or get a program called SpeedFan - Access temperature sensor in your computer it can tell you the temperature.
    But yeah cleaning out dust will allow better airflow and keep it from overheating.
  5. Posts : 4
    Well here are some pics of Speed Fan With Only Google Chrome Open ( https://www.dropbox.com/s/slum5tlu74uhcaa/Lol.JPG
    With Google Chrome and Halo CE ( https://www.dropbox.com/s/zmj7sj7uvwbh15p/12.JPG?m )
    With Google Chrome ,Halo CE and Jdownloader ( https://www.dropbox.com/s/ytry1v4f66...ture%2B%2B.JPG)
    I cant clean the dust now because well its 3am here -_-.
  6. Posts : 30
    I would say, tomorrow try cleaning out some dust. And recheck it.
    I recommend a can of compressed air, and anti static cloth? I think thats what they are. And give your PC a good clean.
  7. Posts : 4
    Ok thanks for all the help :).
