Windows 7: Computer *Jet Engine Sound* *Using Too Much Memory*
25 Jul 2013   #1
Batomega5
Windows 7 Ultimate 32 Bit
My computer has started to sound like a jet engine when it starts consuming memory almost all of it with only google chrome open right now its consuming 1.12gb when i turn it on it sounds like a jet engine and when i play ang games even halo and it starts consuming memory it starts making that terrible sound.
https://www.dropbox.com/sh/92bzcs9n29c398j/1JVSkYoEpD
Some images of the task manager
25 Jul 2013   #2
silents429
Windows 7 Ultimate 64 bit
Well the memory and cpu usage seems fine, Um. Have you tried cleaning out any dust? or making sure the computer isn't heating up? I know the fan on my laptop doesn't kick up the power until I accidentally block the fan.
25 Jul 2013   #3
Batomega5
Might be heating up . how do i check to see if it is? and no i have not tryed cleaning any dust .
25 Jul 2013   #4
silents429
Well if it sounds like the jet engine feel around, or get a program called SpeedFan - Access temperature sensor in your computer it can tell you the temperature.
But yeah cleaning out dust will allow better airflow and keep it from overheating.
25 Jul 2013   #5
Batomega5
Well here are some pics of Speed Fan With Only Google Chrome Open ( https://www.dropbox.com/s/slum5tlu74uhcaa/Lol.JPG
With Google Chrome and Halo CE ( https://www.dropbox.com/s/zmj7sj7uvwbh15p/12.JPG?m )
With Google Chrome ,Halo CE and Jdownloader ( https://www.dropbox.com/s/ytry1v4f66...ture%2B%2B.JPG)
I cant clean the dust now because well its 3am here -_-.
25 Jul 2013   #6
silents429
I would say, tomorrow try cleaning out some dust. And recheck it.
I recommend a can of compressed air, and anti static cloth? I think thats what they are. And give your PC a good clean.
25 Jul 2013   #7
Batomega5
Ok thanks for all the help .
Ive increased memory RAM from 1g to 4g but now have no sound, why?
Hi there, I have just increased the memory on my Packard bell istart 2479 and since doing so, I have no sound. The Speaker symbol in the bottom corner has a red x on it and it says No Audio output device is installed. This is really starting to frustrate me now because I cant seem to fix it....
LOW Computer Memory- ONLY 90MB or less Free Memory? Soo much lag?
Hello, i have a Windows 7 64bit OS and i am running a Laptop. Ever since i had this virus (Win32 malware gen) which kept coming up with a notifications of the virus on avast every 2-5 minutes my computer was running slow and when i deleted the virus, by dragging it in to the recycle bin and...
Performance & Maintenance
LOW Computer Memory- ONLY 90MB or less Free Memory? Soo Slow?
Garbled sound NF4/Sound Blaster XFi Gamer with over 4GB memory
This seems to be a problem that Creative has not been able to fix with new drivers. The work around is to limit the computer to below 4GB of memory. Has anyone come up with drivers that work so I can use all my memory?
Drivers
computer looping sound automatic restart computer
acer aspire z5610 i have my computer is on for maybe hour or so then i hear the beep then stop then beep comes back looping sound continues then computer freezes then automatically shutdown restart it self i took it back to acer giving them say problem they did the test but they said they...
BSOD Help and Support
No sound with 4GB memory on the laptop
I have an Compaq CQ40 Laptop and today I changed the memory from 1GB to 4GB but after upgrade I do not have sound at all even if the hardware is ok and fully functionally. I took one af the sticks and put the old 1GB stick and is working Now the problem is when I put both 4gb i do not have...
