Windows 7: Encrypted Volume Check: Volume Info on \\?\Volume{X}Can't read
19 Sep 2013   #1
glennc
Windows 7 Ultimate
Encrypted Volume Check: Volume Info on \\?\Volume{X}Can Not Read
Found this in my Event Viewer on each start/restart. I don't have any Volumes that I have encrypted. Is this malware? I've run everything prior to noticing including Windows Offline Defender.
Not sure if this is even the correct area to post this!
Glenn
19 Sep 2013   #2
YoYo155
Windows 10
I'm going to take a guess, please upload a screenshot of the disk manager (Windows Key+R to open the Run dialog, type diskmgmt.msc, and press Enter).
Posting the actual entry from the Event Viewer can help.
19 Sep 2013   #3
glennc
Windows 7 Ultimate
Quote   Quote: Originally Posted by YoYo155 View Post
Hello and thanks for responding. Here is a view from the event viewer, I'll do it with diskmgmt.msc if it is still necessary!
Encrypted Volume Check: Volume Info on \?\Volume{X}Can't read-capture.png
Glenn
19 Sep 2013   #4
glennc
Windows 7 Ultimate
Here is the diskmgmt shot!
Thanks for any assistance!
Glenn
19 Sep 2013   #5
YoYo155
Windows 10
The more info the better the thing I don't quite understand is how is this an issue in your eyes?
Have you experienced any problems?
I don't have Windows 7 Ultimate so I can't try and reproduce this condition.
I would go into the registry and search for the value inside the {} to see who's it's parent.
A word of caution! DON'T change anything.
19 Sep 2013   #6
glennc
Windows 7 Ultimate
Hello YoYo155,
I don't have the experience of confidence to try that without help..... But looking at the disk management page on Disk 0 the first 100 MB partition is supposed to be the System Resereved IIRC. It is now unnamed and doesn't look right!
Any ideas?? Thanks again
Glenn
19 Sep 2013   #7
derekimo
Mine is unnamed too, it is still system reserved though.
19 Sep 2013   #8
YoYo155
Windows 10
No I don't believe that to be the problem, or any problem for that matter.
If I may ask, what made you go and look in the event viewer in the first place, did some issues arise?
with that said, you can look in the registry by Windows Key + R and typing regedit then pressing Enter (accept the UAC [User Access Control]).
In the registry the first thing you do is File>Export (make sure that the export range is set to All [a bullet point at the bottom left]) and save a backup.
Then hit the F3 key and enter the string (the series of characters between the {} and search.
Let us know if something comes up.
But really I have to stress is there a problem?
20 Sep 2013   #9
glennc
Windows 7 Ultimate
Quote   Quote: Originally Posted by derekimo View Post
Thanks Derek,
I thought I remember it being different, the last time I looked at it. Thanks for confirming!
Glenn
20 Sep 2013   #10
Golden
Microsoft MVP
Windows 7 Ult. x64
Do you have TrueCrypt installed? Any encrypted containers?
Does Deleting USB HardDrive(Volume)Revert It To Inactive Volume
Have an external USB hard drive caddy with a naked Raptor drive sitting in it which has one partition that is the entire capacity of the Raptor drive...this is an 'active' volume. 1. Can someone tell me if I delete the volume under Computer Management>Disk Management>Delete Volume will this...
Hardware & Devices
Soft Recording volume with Blue Yeti, increasing volume distorts audio
So I have a Blue Yeti, and I'm an online animator/voice actor. Whenever I record audio on my Blue Yeti (OR any other mic) I record about 4-6 inches from the mic, and turn the gain down enough that the audio doesn't peak as I yell or whatever. This is what you're supposed to do if you don't want...
Volume Buttons is not adjusting volume on new keyboard
Hello sevenforums, I just received a new keyboard today: Thermaltake Challenger Ultimate. I went from a Logitech G15. First thing I did was connect the keyboard and install the software that came along on the CD, it probably also installed the correct drivers. First after this did I uninstall...
Hardware & Devices
Format accident on encrypted volume
I've got an encrypted by truecrypt 1G WD elements SE volume. Before accident, every time when I plugged this volume into my notebook, my system (windows 7 64) showed me a popup massage "You need to format the disc in drive I: before you can use it". I didin't turn off it (I haven't known how), of...
Hardware & Devices
How to increase max volume and decrease minimum volume
I use W7's volume control for the studio monitors I use. It's not practical to use the knob on the monitors since it is located in the back. The max volume (100%) in W7 is not loud enough while the minimum volume (0%) still makes sound when Id like it to be mute if it's at 0% How can this be...
Extremely low volume on headphones but high volume on speakers
y0 I got this other problem i really hate. The most. Please jonathan_king, zigzag reply please. I beg you, i got this problem that i plug in my headphones and its extremely low volume. It use to work fine, but now nope. I tried the jacks on the front, back and my monitor. Please help me.
