Windows 7: Power saver on battery not changing taskbar colour
28 Dec 2013   #11
Mysterious
Windows 7 Ultimate x86
ok i'll ...wait for my reply
29 Dec 2013   #12
Mysterious
Quote   Quote: Originally Posted by Mysterious View Post
Hi Jerry,windows didn't find anything >>
29 Dec 2013   #13
Mysterious
I installed Power 4 Gear utility & it is normal now.it changing to basic colour when on battery (Power 4 Gear Battery saving plan)
but i dunno why it not doing that on windows default power saver plan,before it was all right ?
29 Dec 2013   #14
Bongo
Win 7 Pro x64 / Win 10 Pro
I am not sure if Windows does it, but it looks like you need the software to do it.
Jerry
29 Dec 2013   #15
Mysterious
Quote   Quote: Originally Posted by Bongo View Post
Jerry
i think windows does it.anyway should i mark this thread as solved now ?
29 Dec 2013   #16
Bongo
I have not seen it in windows myself and have been using a laptop for 5+ years, but have not tried to.
It's your chose if you mark as solved, I am out of ideas.
Jerry
30 Dec 2013   #17
Mysterious
Jerry
ok,i'll search for it & if i feel necessary.i'll mark it as solved
30 Dec 2013   #18
Mysterious
Jerry
see this,this user had same problem & he sloved it >>
power management - Windows 7 Aero theme when on battery - Super User
Edit-and i also solved it by this way
30 Dec 2013   #19
Bongo
Jerry
That's good to hear you got it, by the way which fixed did you use there's like three or four on that page.
Jerry
30 Dec 2013   #20
Mysterious
Jerry
The first one,that user marked that best answer also
Changing the folder background colour
Hi I have been getting headaches and wanted to change the glaring white colour of the background :( I have gone through control panel, display, window colour, advance appearance settings, window and changed the colour. But this doesn't affect the folder background colour. How can I change...
Customization
Changing out of windows 7 basic colour scheme
So i have had this for only about an hour, but it is really bugging me. I have also read through other posts on this site and they haven't helped. I used a program which changed my colour scheme to basic. This wasn't the first time a program had done that, but when i closed the program it did not...
Customization
Taskbar colour is not changing !
When I wanted to change my desktop wallpaper and also the taskbar colour. I click on the theme I want, then I see the taskbar not changing. Then I click on Window Colour : http://i.imgur.com/u4FIU.png Then I get this : http://i.imgur.com/TCYdt.png But I should get this :...
General Discussion
Changing windows classic taskbar colour?
I've been using windows classic over basic/aero due to streaming purposes (streaming with aero creates issues and I'm not a fan of basic), I like a darker/dark grey theme most of the time as it's easier on the eyes and the bright white windows classic taskbar is a bit of a pain, but I can't figure...
Customization
Changing font colour on desktop
Hi all. I almost solved all my problems with windows 7, but this i think is the last one. I got a white picture on my desktop, but the font under my icons is also white, so i almost cant read what it says, so i want to turn it black. How do i change the colour? Thanks in advance (dunno if it's...
Customization
Changing the taskbars colour completely?
Hi, I'm new here :) I'm currently using a modified for dual screen version of: Knife by *Mikeinel on deviantART as my wallpaper, because of that I want an completely or atleast mostly white taskbar, but Windows won't do that :cry:, this is my best result, which have a lot of blue in both ends,...
Customization
Đ Designer Media Ltd
