Power saver on battery not changing taskbar colour
Page 2 of 2 FirstFirst 12
  1. Posts : 108
    Windows 7 Ultimate x86
    ok i'll ...wait for my reply :)
  2. Posts : 108
       #12
    Hi Jerry,windows didn't find anything >>
    Attached Thumbnails Attached Thumbnails Power saver on battery not changing taskbar colour-sfc.jpg
  3. Posts : 108
    I installed Power 4 Gear utility & it is normal now.it changing to basic colour when on battery (Power 4 Gear Battery saving plan)
    but i dunno why it not doing that on windows default power saver plan,before it was all right ?
  4. Posts : 12,120
    Win 7 Pro x64 / Win 10 Pro
       #14
    I am not sure if Windows does it, but it looks like you need the software to do it.
    Jerry
  5. Posts : 108
       #15
    Jerry
    i think windows does it.anyway should i mark this thread as solved now ?
  6. Posts : 12,120
       #16
    I have not seen it in windows myself and have been using a laptop for 5+ years, but have not tried to.
    It's your chose if you mark as solved, I am out of ideas.
    Jerry
  7. Posts : 108
       #17
    Jerry
    ok,i'll search for it & if i feel necessary.i'll mark it as solved
  8. Posts : 108
       #18
    Jerry
    see this,this user had same problem & he sloved it >>
    power management - Windows 7 Aero theme when on battery - Super User
    Edit-and i also solved it by this way
  9. Posts : 12,120
       #19
    Mysterious said:
    Jerry
    That's good to hear you got it, by the way which fixed did you use there's like three or four on that page.
    Jerry
  10. Posts : 108
       #20
    Jerry
    The first one,that user marked that best answer also :)
Đ Designer Media Ltd
