Windows 7: Missing power state controls in advanced power plan settings
13 Jul 2014   #1
KAAMO
Windows 7 Professional
Hi guys, I'm new here and this is my first post. I have an Optiplex 745 running Windows 7 Professional. Normally in the advanced setting section of the power plan option I have the option to change the power state, however all of a sudden these options have just totally disappeared. Any help is appreciated.
Thanks in advance.
14 Jul 2014   #2
AddRAM
Windows 7 Pro x64 Windows 10 Pro x64
What Power plan are you using ?
Balanced, Power Saver or High Performance ?
Also, run a System File Check
Use option 2
14 Jul 2014   #3
KAAMO
I am using High Performance. I am not getting the option in any powerplans.
14 Jul 2014   #4
KAAMO
I have tried the fix stated in option 2 but still no luck unfortunately
15 Jul 2014   #5
Vuxy
Hello Kaamo,
Thanks for posting your question.
Is this a most recent issue you are experiencing? If it is, why not try to system restore to before it was happening?
1. When turning on your computer, continuously tap F8
2. Select Repair Your Computer.
3. Select System Restore.
Make sure to restore to before the issue was occurring.
Thank you,
VinnyBuxton
16 Jul 2014   #6
KAAMO
Brilliant, Ill give that try now and see if that solves it. Thankyou.
16 Jul 2014   #7
KAAMO
A system restore hasn't fixed it unfortunately.
17 Jul 2014   #8
Vuxy
Hello Kaamo,
Please post a screenshot of the issue. Screenshots and Files - Upload and Post in Seven Forums
Thank you,
VinnyBuxton
[Power Plan] Turned off HDD state causing rest of system to delay
Hello, When I try to access *some* data on my SSDs, the computer to wait on the HDD to spin up should they happen to be turned off (power plan settings). Is this an inherent problem with Windows 7?
Performance & Maintenance
Power plan - do not keep settings!
Hi, I'm running Win7Pro 64bit in a Tecra R840 laptop. My power planning regarding LCD brightness is 40% if running on batery and 100% if plugged in. The problem is that, for some reason, I can't keep these settings and Windows (?) change it to 40% on batery and plugged in. Example: I...
How can I change power plan and run scripts based on power state?
I overclock my CPU by changing its FSB and I have scheduled (Task Scheduler) this script to run every time I logon to Windows. But I would like to schedule it to downclock when I pull the power cord and then overclock as I plug it back in. Is this possible? It would also be nice if Windows changed...
General Discussion
Power Plan - Create Shortcut to Change Power Plan
How to Create a Shortcut to Change Power Plans in Windows 7 and Windows 8 This tutorial will show you how to create or download shortcuts that will allow you to change or switch to the High Performance, Balanced, Power Saver, or a custom power plan instantly without having to go through Power...
Tutorials
Power Options/Power plan settings?
From Windows 98SE/2000/XP SP3 I always set my power settings as always on/never shut down (hard drive always on) with the exception of turn off display after 10 mins. Both my PCs are on for about 16-20 hrs each day and I always shut them down manually every night. Now in Windows 7, I created a...
