Windows 7: Aero Peek, scroll-wheel click/"click-and-hold" scrolling does not work
30 Nov 2014   #1
vv211
Windows 7 Professional x64 w/SP1
So, every once in a while I come across this strange issue:
1. Aero Peek suddenly stops working
When I hover my mouse over windows on the taskbar, the windows preview will flash for a fraction of a second and then vanish, if I'm moving my mouse along the taskbar the window preview will quickly "blink" (it appears and disappears) for as long I'm moving my pointer across that program's area on the taskbar, but nothing even remotely clear enough to see what's in that window. Once I stop moving the mouse, even while in that program's title area on the taskbar, i can't get the "blinking" effect to come back for that specific one unless I move my mouse off of it and then back on.
2. Clicking with the scroll wheel to scroll stops working
I like to scroll pages by clicking and holding with the scroll wheel, then I release when I get to where I want to be. But that functionality no longer works, nor does simply clicking once and then moving the mouse to scroll. When I try either of these methods, the small white circle with the arrows which indicate that you've clicked to scroll with the mouse wheel will flash on the screen for an instant then disappear.
What I've tried:
Restarting computer (works, but is a nuisance especially if I have a lot of tabs open in Chrome)
Ending every non-essential process in task manager, including explorer.exe and dwm.exe (doesn't work)
Disabling everything in Performance Options > Visual Effects (doesn't work)
Virus Scans (always come up clean)
There doesn't seem to be any sort of trigger which causes this to happen. I usually only notice that it's happened when I try to scroll in Chrome and it doesn't work, but a few times I've gone to open one of the other windows I have and notice that the preview for it didn't pop up when I put my mouse over it.
I've tried Google'ing it and I haven't been able to find anything similar to what I'm experiencing, and thus no solutions.
Clicking with the scroll wheel works as it should for other purposes, such as opening a new tab.
These issues never appear individually, only together.
System specs:
Windows 7 Pro x64
32GB RAM
50+GB free on C:/ and 100+GB free on D:/
Thank you for any help you may give, it's very much appreciated.
30 Nov 2014   #2
vv211
Well, played a round of payday 2 with a friend on steam. Went on the steam in-game browser during it and magically I could scroll again. Symptoms were gone after I exited the game as well
Mouse double clicks when I click once and click when I hold it.
What I mean is that let's say I am trying to hold and drag a desktop file it will sometimes just click, making me drop the file on the spot. It will also double click when I try to make a single click. I tried to lower the settings for double click timing on the settings menu. EDIT: Tried out...
Hardware & Devices
When I click "install now", it's saying "No device drivers were found"
Ok, now I get another problem... When I click "install now", I get a msg box that is saying 'no device drivers were found. Make sure that the installation media contains the correct drivers, and then click OK' What should I do now?
Installation & Setup
Aero peek, right click, "tasks" how to disable?
P L E A S E help me before I lose my mind ...:cry: http://oi39.tinypic.com/2dwhtep.jpg As you can see above, when I right click any icon in Aero Peek, I have a separate section called Tasks. Open new tab, Open new window and so on. How do I disable this annoyance? I am not wanting to...
General Discussion
A question regarding the "scroll on click" feature
Hello I'd like to ask you, whether there's a way (internally or via 3rd party software) to disable the feature which is slowly starting to drive me nuts. Namely, if you change your window layout to "list", you end up with several columns of files. If you try to click on a file which isn't in the...
General Discussion
When holding ctrl - left click'n'hold is sometimes "sticky"...
Let me explain: if I keep ctrl button pressed and then click and drag with left mouse button (selecting text or using photoshop) this drag is sometimes "sticky" - when I finally release the mouse button system does not stop dragging. It behaves as I would still hold the left mouse button...
General Discussion
How Do I Disable Taskbar Thumbnail "Aero Peek"?
I apologize in advance if my thread is a duplicate of another thread. My problem is difficult to describe, so I could not find anything through the forum search or Google. I'll begin by stating what I'm not looking for: I'm not looking for how to increase the delay or the duration of the...
Customization
