Windows 7: Power usage and Power savings settings questions
20 Dec 2014   #1
groze
W7 32 bit, Linux Mint Xfce 18 64 bit
How much power does an dell inspiron 2020 all in one desktop if left on 24/7 with all the power savings settings disabled? I don't leave it on 24/7 but I am trying to get a cost of usage per hour in various modes.
I would also like to figure out how much less it would use if you put windows 7 in sleep mode or hibernation mode lets say an hour.
I am also trying to figure it how much it would save money at night if I just unplugged everything.
We are on Duke Energy Indiana, U.S.
Does a Screen Save use less or more power?
Thank you for this information in advance.
20 Dec 2014   #2
AddRAM
Windows 7 Pro x64 Windows 10 Pro x64
No clue. You`d have to compare 2 elecrical bills, but someone will come along with a technique.
You should never leave a pc on 24/7 if you`re not using it, that`s just crazy IMO.
You should have the monitor going off after 10 to 15 and sleep or hiber after 45 to an hour.
Of course a screensaver uses more power and just heats up the video card, no need to even run one.
20 Dec 2014   #3
groze
The only time I leave a computer on 24/7 is when doing a very large download overnight. I set the monitor to go off in 15 minutes when I do that but leave the hard drive on. I am going to start unplugging it at night.
Missing power state controls in advanced power plan settings
Hi guys, I'm new here and this is my first post. I have an Optiplex 745 running Windows 7 Professional. Normally in the advanced setting section of the power plan option I have the option to change the power state, however all of a sudden these options have just totally disappeared. Any help is...
General Discussion
PSU mains power usage
I have had a good look around for how much power my PSU's are using and have got some quite weird answers. One in particular said that the mains power usage / current draw is around half of what the PSU puts out. Now using that logic my latest - Corsair HX 1050 rated a bit below that figure it...
Hardware & Devices
670 power usage
can you run a GTX 670 on a 650W power supply?
Graphic Cards
computer power usage
my computer does not say how many watts it uses it is a packard bell ipower x8870 a nvidia 8800gtx 3gb ram 1333mhz two hdd 500 each drives 52000rpm with a quad intel core 2 Q6600 2.40ghz so how any watt does it use on the electricity please
General Discussion
Several Power Questions
Hello, I am looking for some learned answers to some newbie basic computer power questions. 1. Is it true that no power strip will protect the computer from a direct lightning strike? Having had a couple and lost a 17" Monitor to them, I am wondering. 2. Is it best to unplug computer from...
General Discussion
Power Options/Power plan settings?
From Windows 98SE/2000/XP SP3 I always set my power settings as always on/never shut down (hard drive always on) with the exception of turn off display after 10 mins. Both my PCs are on for about 16-20 hrs each day and I always shut them down manually every night. Now in Windows 7, I created a...
Performance & Maintenance
