Windows 7: Prevent switch from Balanced power mode to Power Saver mode
14 May 2015   #1
JayUSA
Win 7 Pro
Hello,
My computer seems to switch to Power Saver mode of its own volition. I'm not sure what triggers the switch from Balanced mode to Power Saver. Yes, I know and how to prevent screen dimming and sleep mode, and I know how to change the plan settings for any power mode...
...but what is the specific setting I need to use to prevent my computer from ever automatically switching to power saver mode? I want it to boot up into Balanced mode, and never, ever switch from that plan.
Thanks!
Jay
14 May 2015   #2
DavidE
Multi-Boot W7_Pro_x64 W8.1_Pro_x64 W10_Pro_x64
Do you have some program in auto startup that might be doing this ?
Laptops may come with some utility for this ???
You could review your startup programs, or try a clean startup.
Troubleshoot Application Conflicts by Performing a Clean Startup
14 May 2015   #3
RolandJS
Windows 7 Professional 64-bit
The only sure way is to set both the Balanced and the Power Saver to the exact three conditions listed in both of them. Power Saver kicks normally in when laptop detects its on DC only.
14 May 2015   #4
UsernameIssues
W7 Pro SP1 64bit
The Dell laptop that I use does not switch power plans. I uninstalled Dell's add on that does that switching.
On some laptops, I leave the OEM app for power monitoring because it also handles cutting off charging when it is not needed (more accurately, the app communicates with the chips in the battery pack - which oversee charging patterns). In those cases, I try to find a setting to tell the app not to switch power plans. If there is no such setting, I do what RolandJS suggested: make the applicable power plans have the same settings.
Windows 7 Power settings keeps reverting back to [ Balanced Plan ]...
I been noticing lately that every time I open my power settings in the control panel, it shows the "Balanced Plan" ticked despite the fact that I've changed it to "High Performance" several times in the last month. Another thing that concerns me is that usually whenever you make any changes to...
Performance & Maintenance
Balanced Active Power Plan?
Hi, Are these the correct defaults for Balanced Power Plan as shown in the attached shots? Thanks.
Hardware & Devices
no balanced power plan
hi all, i just recently noticed that my laptop does not have a 'balanced' power plan. It only has: 'HP optimized, high performance and power saver'. Does anyone know why 'balanced' isn't available?
after 4 minutes monitor wakes up from power saver mode
I set my screen saver to blank after 4 minutes and my monitor to power down after 5 minutes. After 4 minutes I hear the Windows seven default sound for log off (I think) and the screen powers up but the blank screen saver stays on. This only happens when I have a check mark by show the welcome...
General Discussion
Windows 7 power plan Balanced or High Performance?
so i was running tuneup utilities and its giving me recommendations to optimize my comp. it has the option of setting my power plan to be balanced or for high performance, what does the majority use? if i go with high performance does it really kill that of power, resources etc that much?
power option reverts back to balanced on startup
I have tried to update my video driver, but that didn't do much. Also changed all my plans to default state. Any idea guys? This is for 64-bits Win7
