Windows 7: INPUT problem. Exit typing mode without reason. HELP
18 May 2015   #1
Cruiss
I bought a new laptop and installed windows 7 ultimate and the drivers from the hp site.
I still have to activate the windows, but the annoying problem is
WHEN I ENTER THE TYPING MODE IN ANY WINDOW (CHROME, INTERNET BAR SEARCH, MICROSOFT WORD ETC.) I CAN TYPE FOR LIKE 5 SECONDS THEN I HAVE TO CLICK AGAIN THE BAR IN ORDER TO TYPE AGAIN.
Is it maybe from the input driver? I can't seem to figure out how to fix this and it really annoys me.4
Please help
18 May 2015   #2
GokAy
Some program possibly stealing focus from the one that you are entering text. Which one I have no idea and not sure how I would diagnose.
Try disabling one program at a time in task manager and see if you can pinpoint the culprit.
18 May 2015   #3
Cruiss
Do you spot anything ?
18 May 2015   #4
GokAy
I don't believe anyone can spot from a screenshot, I am sorry. You will have to end processes one by one and see if you can write without an interruption. (Not all processes will be endable and some may cause a problem when ended, don't worry if so and just restart the computer)
You can also go into Safe Mode and see if you can write alright there.
Perhaps someone who knows better will comment.
18 May 2015   #5
DavidE
Multi-Boot W7_Pro_x64 W8.1_Pro_x64 W10_Pro_x64
First try Safe Mode as GokAy suggested.
If you don't have the problem in Safe Mode, try a Clean Startup:
Troubleshoot Application Conflicts by Performing a Clean Startup
In the screen print in post #3 you need to click on Show processes from all users to see all the running processes.
Where did you get the Ultimate DVD ?
18 May 2015   #6
Boozad
Why haven't you activated Windows yet?
19 May 2015   #7
Cruiss
@DavidE: I searched as you sugested in the show all proceses and found the x64 synaptic something. I figured it out it must have been something from the drivers I installed from HP site. Thanks for the suggestion
and @Gokay : also thank you!
19 May 2015   #8
DavidE
You're welcome and glad to hear you fixed it
typing cursor disappears when typing and deselects typing box
hi guys, whenever i start typing the cursor disappears and i have to repeatedly keep clicking back in the typing area multiple times in order to type a few letters more b4 it happens again. can someone plz help. i tried alot of things already
General Discussion
Windows 7 Lag - open/close apps, typing, etc. even in Safe Mode
Sony VAIO VPC series laptop w/ Core i7 Q740 w/4GB RAM working on for a client. Malwarebytes pulled up 26 infections, and I thought that was the solution to constant lag problems and lag when typing. Turned Norton features off, CHKDSK, adjusted desktop setting for Best Performance, ran in Safe...
General Discussion
Cannot exit sleep mode
First the system specs: Intel DX48BT2 motherboard Intel QX9770 3.2 GHz Core 2 Extreme Nvidia GTX 295 8GB of OCZ 1333MHz DDR3 Gold Series RAM 30GB OCZ Vertex SSD 1TB Samsung HD103UJ HDD Windows 7 SP1 Public Beta For two nights in a row whenever I have put my computer to sleep before I go...
General Discussion
XP Mode wouldn't install solved, thought I would pass along the reason
I recently installed Win7 Ult 64bit which for me was an upgrade from XP Pro 32. Pretty much every former program I had worked albeit one which was a 16 bit program, AutoCADLT 97, that wouldn't even load. So with recommendations from members on the board, I went to install the...
Virtualization
Problem with keyboard and typing
My laptop is a HP G5056EA and I recently installed windows 7 on it. Its running perfectly except that when im typing the little flashing line will skip back a few words at random. Ive never had this problem before installing windows 7 so Im assuming its a problem with that.. Its not my finger...
Performance & Maintenance
typing problem
typing problem in pc :cry:.while typing many single words at a time ththhhhhhhhhhhhhhhhhhhhh spacebar also gives many space at same time.mouse also hangs several time:cry:
BSOD Help and Support
