Windows 7: Monitor Power Off vs Display Off via Power Plan
31 Jul 2015   #1
MourningStar
I prefer to manually power down the monitor rather than rely on the "Turn off the display" setting in Power Plan Settings. Is there a major difference? Good, Bad, Ugly, das macht nichts? Any critical concerns I need be aware of?
-thx
31 Jul 2015   #2
Layback Bear
Windows 7 Pro. 64/SP-1
I don't know of any G/B/U. What ever way you choose.
I personally turn power off to my computer and everything plugged into it after a proper shut down.
31 Jul 2015   #3
MourningStar
I appreciate your input Layback Bear. Circumstances require my computer to be running for long periods of time. The monitor is not needed for much of that time.
-thx
31 Jul 2015   #4
LMiller7
Windows 7 Pro 64 bit
There is essentially no difference.
01 Aug 2015   #5
Ranger4
I have my monitor set to power down after 5 minutes of no activity. If I am to be away for sometime I shut the monitor off.
I do shut my computer down at the end of working, shut off the UPS & turn off the wall switch as well.
01 Aug 2015   #6
MourningStar
Thank you LMiller7 and Ranger4. Issue resolved -
Power plan?
Any changes you expert would recommend to the screenshots. Thanks.
Performance & Maintenance
Missing power state controls in advanced power plan settings
Hi guys, I'm new here and this is my first post. I have an Optiplex 745 running Windows 7 Professional. Normally in the advanced setting section of the power plan option I have the option to change the power state, however all of a sudden these options have just totally disappeared. Any help is...
General Discussion
how to let power plan do this
so i tried changing power plan settings in one user and its changed in the other user how to let power plan have a separate one for each user using windows 7 home premium or ultimate also chose what the power button does settings deferent for each user
General Discussion
How can I change power plan and run scripts based on power state?
I overclock my CPU by changing its FSB and I have scheduled (Task Scheduler) this script to run every time I logon to Windows. But I would like to schedule it to downclock when I pull the power cord and then overclock as I plug it back in. Is this possible? It would also be nice if Windows changed...
General Discussion
Power Plan - Create Shortcut to Change Power Plan
How to Create a Shortcut to Change Power Plans in Windows 7 and Windows 8 This tutorial will show you how to create or download shortcuts that will allow you to change or switch to the High Performance, Balanced, Power Saver, or a custom power plan instantly without having to go through Power...
Tutorials
Power Options/Power plan settings?
From Windows 98SE/2000/XP SP3 I always set my power settings as always on/never shut down (hard drive always on) with the exception of turn off display after 10 mins. Both my PCs are on for about 16-20 hrs each day and I always shut them down manually every night. Now in Windows 7, I created a...
