Problem at the start up :(
Page 2 of 2 FirstFirst 12
  1. Posts : 6,618
    Saptha said:
    SEEKERMEISTER
    n why is that my desktop appears in classic mode ?? :|
    Is this a result of the problem above or the steps that you have taken since posting this thread, or is this an unrelated problem?
  2. Posts : 10
       #12
    seekermeister said:
    Saptha said:
    SEEKERMEISTER
    unrelated
    buh I do face this ...
    How to fix it??
  3. Posts : 6,618
    Assuming that you didn't change it yourself, I would suggest running the Aero Troubleshooter. Often it will find that the Desktop Window Manager Session Manager service has been disabled.
    EDIT: Type it into the search window of Help and Support. It will be item #1 in the list. run it and follow the wizard.
  4. Posts : 10
       #14
    Aero is not available in windows 7 basic esition
  5. Posts : 10
       #15
    I do not face this problem every time I log in
    It only happens when I see
    " Preparing your desktop " instead " Welcome" screen
  6. Posts : 6,618
       #16
    It would help if you filled out your system specs. I'm not familiar with the differences of the basic edition, so someone else probably can answer your question better than I can. However, do you have "Personalize" on the context menu, when you right click the desktop? If so, there are a number of items to check, but it would be easier for you to simply check them out for yourself, since I'm not certain of how they might differ from what I use.
  7. Posts : 10
       #17
    Nope :|
    buh, I do rememba when I faced this problem for the first time
    It showed an error message that some file in a folder "windows" is missing or misplaced ..
    If that is the case .. probably I should face this problem every time I log in ...
    ain't it ??
  8. Posts : 6,618
       #18
    It would seem likely, but if you remember when the problem began, you should check to see if you have a Restore Point available that would correlate to a point just prior to that date, and run a System Restore, if that doesn't go too far back. The System Restore Wizard should tell you what programs that you have installed since, which would be effected. Take note of them so that it will be easier to reinstall them.
  9. Posts : 10
       #19
    Okie ..:)
