Right Click Menu Display Problem
  1. Posts : 21
    Win7 Ultimate
    Hi all,
    I have a strange problem. When I right click on a file (.exe, .dll, .jpeg, ...) I end up with a screen as in the attachment. (It should be like in http://images.maketecheasier.com/200...py-move-to.gif )
    However, there is no problem when I right click on desktop, it is as it should be (no blue band). I have a desktop PC and a laptop and both has the same problem. I tried system restore but no solutions What can be the reason? A virus or a malware (despite Avira and A-squared installed)?
    Attached Thumbnails Attached Thumbnails Right Click Menu Display Problem-adsae-z.jpg
  2. whs
    Is it always the same entry that shows in blue? If yes, what is it (hard to read the entries in your language). Anyhow, the desktop right click menu is different to other right click menus.
  3. Posts : 2,651
    W7 RTM Ultimate x64
    Would help if you could translate it to English...
  4. Posts : 21
    Win7 Ultimate
    All the entries are in blue (winrar commands, copy, cut, etc.) I will format win7 on my desktop PC but dont want to do the same for my laptop. I want to learn the magic behind this. If you want english version of the menu, it is as follows:
    Open
    Print
    Create PDF and Bitmaps using PDF creator
    open with
    Share with
    Scan selected files with avira
    add to archive
    and regular winrar stuff
    jetaudio
    load previous versions
    send
    cut
    copy
    create shortcut
    delete
    rename
    properties
  5. Posts : 21
    Win7 Ultimate
    Problem Solved:
    The reason is a beta version of a-squared ant malware installed. After uninstall it, the problem disappeared.
