problem - computer hangs after a bit when charging
  1. Posts : 2
    windows 7
    i use dell inspiron 1564 with genuine windows 7.
    it works well when on battery but when i plug in charger,it hangs after some time......
    can someone tell me. i am totally upset....
  2. Posts : 17,796
    Are you overheating when charging?
    Is your computer overheating?
  3. Posts : 2
    windows 7
    no but charger gets very hot....
  4. Posts : 17,796
    Check the temp with my link, above. You may be surprised.
  5. Posts : 914
    Windows 8 Pro
    I would contact Dell.
    Backup all of your important data as well.
  6. Posts : 17,796
    Good idea, and you should do it, but read this first
    https://www.sevenforums.com/software/...ll-7-12-a.html
  7. Posts : 914
    Windows 8 Pro
    Are you using a universal plug adaptor, or a universal power supply?
