HELP!! Same problem as many. Graphics card wont be detected!!
JoeyDynamite
10:08 PM
SO i just upgraded from vista to Windows 7 on my Laptop and now my g.c. wont be read like alot of others. Ive tried going to nvidia and find a drive but none work. they keep saying there is no card that can be found and all that fun stuff so if any one can help me id appreciate it.
MY SPECS
Gateway FX Laptop
Model # P6831
Proc Intel core 2 duo t5550 @ 1.83 GHz
Video card i know its a Geforce 8800m but dont know if its GT or GTS
Windows 7 ult 64geforce 8800 GT
Gateway
Windows 7 ult 64
geforce 8800 GT
MY SPECS
Gateway FX Laptop
Model # P6831
Have you checked BIOS to see if the card is enabled?
Ken J
HP Pavillion dv-7 1005 Tx
Win 8 Release candidate 8400
[email protected]
4 gigs
Nvidia 9600M
HD built-in
17" Wxga
none
45Mb down 5Mb up
No i havent checked that out. I will do so right now. Thanks
Gateway
Windows 7 ult 64
geforce 8800 GT
Ok First 2 suggestions would be use manufacturs specs get the seriel do some reaseach on what that maker put into that particular build
Then after you have found this informantion out proceed to check if they have updated drivers available through them
Since windows can't detect or figure it out they should have a moded driver for the win 7 that would be most likely the only steps you can take besides
getting links to possible nvidia software drivers that run on win 7
Yet one more issue may occur if it isn't any win 7 update you're going to have to make do with a vista driver that would be somewhere in the ball park note you won't be doing any more updates for that driver for a while
also suggest if you do gain the driver and detect this system flash it right away and make sure you mark it for future install issues
Almost for got this as well if you upgraded from vista to this platform that might be you're issue there too always do a clean install never upgrade ok i said enough so i hope what i have said works for you :cool:
Enthod Pro Full Tower
Logitech wireless keyboard
Logitech wireless mouse
Cox Cable 100+ mb
IE-10, Chrome, Opera
GPU GTX Gigabyte 970G1
ok so i just looked in the BIOS setup and i have no idea what im looking for. Now i didnt see anything about a graphics card on there.
ANd yes i did do a fresh install of windows 7. I formatted my HD and did it that way. I have looked thru gateway and nvidia all of yesterday and downloaded many drivers. none worked. i will keep at it to try and figure this out.
Gateway
Windows 7 ult 64
geforce 8800 GT
did you try the auto-detect feature at the nvidia website?
did you check gateways website?
windows 7 ultimate 64bitIntel Core2 Extreme x9000 2.8GHZ4Gig2 NVidia GeForce 8800M GTX (SLi)
Alienware AREA-51 M17x
Asus P965 Intel chipset
4Gig
onboard
17in. built-in, 47in JVC LCD
1080p
2 250Gig Hitachi (RAID 0) @ 7200RPM
17in. laptop
touchpad, Logitech Anywhere Mouse cordless laser
cable
yeah but in the bios you would have to go under chipset and check if you have a installed and a onboard it might be conflicting you need to disable something cause something is making it clear that it has another display to use besides the 8800mm
Im sure if you turn this feature off in the bios that would resolved and it would inform you that you need a driver
sometimes onboard graphics will disable a installed card cause i doubt you really be able to look at anything respectivly if it wasnt a dedicated graphics already there
Cox Cable 100+ mb
nvidia reference drivers in a lot of cases won't install on laptop versions of Nvidia GPU's due to licensing with the laptop manufacturers (same goes for ATI/AMD mobility GPU's) and other reasons, and require the INF to be modded in order to be installed (either manually or getting them pre-modded). For pre-modded drivers the best to look for nvidia based GPU's is here,
Drivers | drivers for mobile cards and laptops | laptopvideo2go.com
or if you want to do it yourself you can use something like this (not sure how well it works with the latest drivers),
NVIDIA MobilityModder
or if you know or can find the correct DevID for your particular GPU, add it to the INF yourself.
Me
Win 7 Ultimate x64
FX-8350 @ 4.6 GHz so far
Asus M5A97 EVO
Sapphire R9 270x Dual-X
Acer S232HL Abid
120 GB OCZ Vertex 3
500 GB Seagate 7200.12
Antec Earthwatts 650W Green
Antec Three Hundred
Cooler Master 212 EVO
Logitech G510
Logitech G500s
MY SPECS
Gateway FX Laptop
Model # P6831
Laptop manufacturers sometimes alter the device ID of their graphics adapters, so that generic drivers (such as those downloaded from nVidia drirectly) won't recognize them.
One thing to try: download and install the Vista drivers:
NVIDIA Video Driver version: 7.15.11.6746
They ought to work. Once the graphics card is recognized, you may get newer/better drivers through Windows Update.
I vaguely recall that's what I did with my laptop, which contains an nVidia 8200M graphics device.
Windows 7 Pro X64 SP1Intel Core I7-3930k16 GB Gskill DDR3-2133eVGA GTX680
homegrown
Intel Core I7-3930k
Asus P9X79 Pro
eVGA GTX680
Creative X-Fi Titanium
As PA246Q
1920 X 1200
Corsair Force GT, 120 GB
WDC 1.5TB Caviar Black
PCP&C Silencer 750 Crossfire
Silverstone FT02
Noctua NH-D14
cheap Logitech USB
Microsoft Intellimouse Explorer (old optical) USB
6Mb cable
Pioneer BDR-205
Samsung SH-203B
Monsoon 5.1 speakers
+1 for all that, you can find the DevID by looking in Device Manager, open Properties of the Yellow !, Detail tab, Hardware Ids dropdown:
Windows 7 Professional x64AMD Phenom II X4 9254x1024mb Kingston HyperX DDR2-1066 KHX8500D2/1GAsus GTS 450 OC
Asus V2-M3M8200 Barebones
V2-M3M8200 (basically a M3N78-VM)
Asus GTS 450 OC
Creative Sound Blaster X-Fi Titanium PCIe
Asus 24" LCD VH242H
WDC WD5000AAKS
WDC WD5002ABYS
Seagate ST325062 USB-to-IDE
Fujitsu 160GB Pocket USB HDD
Antec Earthwatts EA-430D
Asus V2-M3M8200
120mm side fan & 80mm front & 92mm rear fan
Dell USB mini Multimedia
Logitech MX518
Comcast Xfinity
Logitech Webcam Pro 9000
Accurian 40-1462 Speakers
little dot MKII Headphone Amp
