Begging YOUUUU For Help Monitor RR problem!
  1. Posts : 4
    Windows 7 64 Bit
    I have got a Problem that is just driving me nuts, Cause i cant enjoy my KotOR 2 game Properly- I got a great computer system, with nice monitor (ASUS Make, runningat 1280x1024 Res)
    And I was Playing and Enjoying the Game (s) with the same resolution for months, at refresh rate 75 all the time.
    Now, i DID switch to another Older system at some point, ie. i have Disconnected all peripherals, Keyboard, mouse AND monitor from my New system, And connected them to the old one- just casue one game doesnt like new 64 bit system- and after i Was done, I reconnected to my new computer again0 And weird stuff started happening- Firstly, my resolution went to 1024x768 . I fixed that in personalisation. When i Launched my KotOR 2 game, I noticed tha the Only Refresh Rate (RR) option was 60 (!!!!), Not 75, so I thought- Okay, this is just current setting in Windows
    So i Went back to personalisation- and in Monitor tab in advanced settings there is ONLY 60! No 75!
    So, Basically, My pproblem is- I had EXACTLY the same monitor, after Briefely switching it to another computer, literally less than a day, I connected it with original one and RR is now locked to 60 for unknown Reason, PLEASE please tell me how to fix it, before i go nuts to extent of actually writing a report to microsoft.
  2. Posts : 6,349
    Model number of Asus monitor?
  3. Posts : 4
    Windows 7 64 Bit
    Wow! that was So fast reply!
    Well, im Not sure, i Got it from friends, is there some way to check it in the windows driver information?
    on the Back it says MM17D, but im Not sure if that is the Actual model.
  4. Posts : 6,349
    Clik here> ASUS - Display- ASUS MM17D
    Checked the pdf manual and it a 75Hz monitor. Wanted to be sure.
    I see you have an ATI video card. If you are using the AMD Catalyst driver/software you will need to select the Hz settting and resolution in Catalyst not through Windows.
    You can check though this thread here> Latest AMD Catalyst Video Driver for Windows 7
    I'm not up on the AMD video hardware/software. I've been using Nvidia.
    I passed on a request to get some of the AMD specialists to come and take a look. They know a lot more than me.
    Good luck.
    Mike
  5. Posts : 4
    Windows 7 64 Bit
    OmG........
    *fAcepalm*
    I somehow KNEW the solution would Be something simple, i sort of SENSED it through the force......
    If I can ever repay you , just tell me, Please.
    Thank you VERY very much.
    I can't believe I just got such an easy solution to the problem, lol......
    pS. can U set karma in These forums? u deffinetely earned quite a few just now.
  6. Posts : 6,349
    You found the settings in Catalyst?
  7. Posts : 11,269
    Windows 7 Home Premium 64 Bit
    Bliznez said:
    OmG........
    *fAcepalm*
    Karma was sent his way.
  8. Posts : 6,349
    I'm not sure if you did this or not but...
    Make sure you turn off the PC and turn off the monitor before disconnecting the monitor.
    If either was powered on when you disconnected the monitor that might have caused the settings to change.
    Just a possibility.
  9. Posts : 4
    Windows 7 64 Bit
    oh, Yeah, i Have managed to Get it, and all Good old bugs with the game came back too Lol xD
    but the Main thing is, That the 75 Option is now availiable in the game menu, i Chose it, and gaming process is back to normal now, Thanks Again)
    Oh, and if some could tell me how to raise karma in Pm, or here, i will give u karma as well ofc
  10. Posts : 6,349
    Glad you have it back to normal.
    Enjoy!
