ATI Mobility Radeon X2300 problem...help please!
  1.    #1
    My computer's graphic card acts strange:
    On ac adaptor power the windows 7 bootscreen freezes long before the Microsoft logo is formed, if i power on my laptop only with battery power everything works fine...does anyone know how to solve this?...I'm assuming the graphic card does this because when i select "PCI Lock" in the boot menu, windows loads with a standard vga adapter driver and bootscreen runs as it should.
    Need your help!
  2. Posts : 1,360
    Then you may have a driver incompatibility.
    When you boot on battery only, your notebook will generally limit the video card to save on battery life. This may be why your computer works when you use it on battery only.
    Try booting up in safe mode and see if that works as well.
    Next, go to your device manager and see if there are any items listed with an exclamation mark next to them. If so, report what they are.
    thanks for the reply Zen00
    If i boot in safe mode no boot logo appears...only list of loaded drivers and then the logon screen. No hardware conflicts/problems in device manager.Now I installed 64 bit edition of Windows 7, the problem pesists but now...it doesn't completely loads the boot screen even on battery power, however, both win x86 and x64 bootscreens load from Hybernate mode...I think is because the video driver is already loaded.In addition, niether Vista nor Seven recognise my videoboard at instalation...a low resolution "safe-mode-like" screen appears during instalation...Is there a way to fix this bootscreen problem?..my guess is if i somehow put the video driver same place as the windows built-in drivers may fix it (if there are in another location :-?), or load the video driver earlier than the bootscreen...
    thanks again for trying to help me!
  4. Posts : 11,408
    ME/XP/Vista/Win7
    Hi adi4motion
    Have on ATI web site for win7 drivers:
    Mobility Radeon™ X2300 - Overview
    i have the latest drivers for vista x64 from asus website and from what i know win7 uses vista platform, so no driver compatibility problem, plus games working fine, aero as well, no complainings about that...just for the bootscreen.On ati/amd website i failed to find the drivers...last was told only the manufacturers produce the drivers for their graphic card (in my case asustek)...(sorry for my english)
    this is what they have support for
    Attached Thumbnails Attached Thumbnails ATI Mobility Radeon X2300 problem...help please!-ati.amd-support.jpg
  7. Posts : 1,360
    Another way to find drivers is to look on your computers manufacturer web site. Check there and they may have what you need.
    Yes, i know that, i have them from my manufacturer site.The ting is that i don't really think is just a driver problem it's more like a driver load problem, because, like i told you if i'm in hybernate mode (shutdown only with drivers already loaded) when i boot up, on windows resume, the bootscreen works...i do have the latest drivers avaible and no driver incompatibility detected.I don't know hoe to solve this, i've tried to change to bootscreen with metods used for vista (didn't work)..the first time they have a nice bootscreen my computer doesn't load it ...thanks for your help...maybe you will solve this ...i don't know...maybe a patch or driver mod?...
  9. Posts : 1,360
    Back there a ways, you mentioned that Windows doesn't recognize your video card, could you expound on that a little? When does it not recognize your card?
  10. Posts : 396
    Windows 7 Professional x64
    Yours is the 2000 series though.
   Please note
Unregistered, once your issue is resolved, please remember to thank those that have helped you and mark the thread as Solved
