Windows 7: Sapphire HD5770 D4000 red led issues. Fan problems?
31 Jan 2013   #1
belnades
Hi, I've been having issues with my HD5770 for a while now and I'm looking for some help.
For the longest time, my graphics card worked perfectly with my computer and everything was fine, I never had cooling issues or anything like that and there really were no problems. Recently my computer would power up for a little while, seem to be working alright, but then shut off if you tried to use it for an extended period of time. Consecutive uses would make the computer shut off earlier than it had the try before, so I assumed the card was overheating. When I opened the case to have a look, I noticed that the D4000 red led was lit and googled for similar issues to my own, and it turned out that the led was related to overheating issues.
When I looked inside the case I noticed that while the fan was turning, it was bugging along slowly and not spinning correctly. I decided to take the card out, apply new thermal compound (along with my CPU) and then put the components back in. Since using the thermal compound (and compressed air to clean the fans and heatsinks), the CPU purrs and is a lot cooler, but the GPU does not work at all.
Now when my GPU is put back in the machine, the fan does not turn at all. All 3 green leds on the card light up and it seems to run fine for a little while, as it had before, but it eventually shuts off (as there is no fan movement) and again, consecutive uses shorten the amount of time the GPU works. I've taken the GPU out again, but I'm clueless about what to do next, should I buy a new fan? There is no debris in the fan and when I spin it lightly with my finger it seems to spin perfectly? Although there is no resist from the fan at all, it is completely loose. I don't know if that is a bad sign.
The GPU is just over warranty by a few months. I also have no idea where to buy a new fan if that's what I need.
Thanks for reading!
01 Feb 2013   #2
Erick Aguilar
Windows 7 professional X64
Did you plug the fan connector back to the GPU PCB? If you say it will not spin at all after you dissassembled.
Also, try using MSI afterburner to regulare your fan RPM's and see if it works with that.
01 Feb 2013   #3
belnades
Quote   Quote: Originally Posted by Erick Aguilar View Post
I did reattach to the PCB. I cannot turn my computer on long enough to check MSI afterburner. There is no spinning at all, no RPM.
01 Feb 2013   #4
Erick Aguilar
Quote   Quote: Originally Posted by belnades View Post
Can you put another fan on the PSU? As in.. a non computer fan, to give it at least some airflow to check if MSI afterburner can regular the rpm?
And by any chance do you use speedfan?
01 Feb 2013   #5
belnades
I don't own another fan, I don't use speedfan.
01 Feb 2013   #6
Erick Aguilar
Well in that case it seems to be a hardware issue.
Pitty that you took it appart and replace the paste. You would have still been able to request support from sapphire, but I doubt they will take it back to have it checked now that it has been disassembled.
01 Feb 2013   #7
stormy13
Microsoft MVP
Win 7 Ultimate x64
Sapphire HD5770 Viper-X: high GPU utilization watching HDTV
Just a question... I recently upgraded my hardware because of a replacement for my old 21" CRT 1280x960 monitor with a new 24" LCD 1920x1200 monitor, being used as Monitor #2 in a 2-monitor setup. Monitor #1 is also a 24" LCD 1920x1200 monitor and remains unchanged. To properly support the...
Graphic Cards
Sapphire HD5770 problem.
I have recently installed Windows 7 Home Premium and now I have a Sapphire HD5770. I have installed it in my PC but the screen is totally black?! I don't get any image or something. but when I use my Nvidia 8500GT it is as normal?! My PC specs: Intel Core 2 Quad Q6600 OCZ 500 Watt...
Graphic Cards
problem!! Sapphire ATI Radeon HD5770
Hi I assume that I have problem with the graphic card. Whenever I watch youtube in full screen, it slows the computer down dramatically to a stage where I have to just turn it off manually. (normal screen= no problem) When this happens, basically computer almost freezes. I also get random...
Graphic Cards
Sapphire AMD 5770 Vapor X issues
My systems specs are: Intel i5 750 CPU 4Gb RAM Sapphire AMD 5770 VApor X Graphics Card Gigabyte GAp55M UD2 motherboard (micro-ATX) 500gig Seagate BArracuda HD Samsung DVD drive 750W power supply With Windows 7 64bit.
Graphic Cards
ATI Sapphire 4870x2 2gb - Win7 - Tons of issues
Hello all, I hope you guys can help me out. I recently upgraded from xp to win 7, did clean install. Install went great, no errors whatosever. However, getting my ati card drivers to work correctly have been a horrendous journey. :mad: Any Catalyst download, or modded ati driver will...
Graphic Cards
Sapphire 5870 Problems installing Drivers
Well I do not really know where to start. I've bought myself a new computer and I'm trying to set it up and completing updating stuff. And Everything goes smooth until the installation of my new Sapphire Radeon Hd 5870 Graphic card. I'm not any expert in this field and could really need some...
Graphic Cards
