kschwarz2002
- Local time
- 12:59 PM
- Messages
- 1
Would anyone know the root cause for this problem.
23 inch monitor with HDMI to HDMI conection. Native resolution is correct, although the Windows screen on the monitor is just a little too big. i.e Start button is half off the bottom left corner and when a window is maximized, the minimize, maximize and close buttons of the window are just off of the top right hand corner.
Would this be a Monitor driver problem, Inegrated graphics card problem, or Windows 7-64 bit problem?
any suggestion would be helpfull on how to resolve or where to look for a fix.
Thanks!
Thanks!
Windows 7 Pro 64-bitIntel i36gbIntel AGP-HD
- Gateway
- Windows 7 Pro 64-bit
- Intel i3
- 6gb
- Graphics Card(s)
- Intel AGP-HD
- Monitor(s) Displays
- Samsung LCD-LED 23 inch
