Computer wont power on after power loss
My computer wouldn't shut down, even with holding in the power button, and so I just let it run out the battery. Then it wont turn on. I tried holding down the power button to clear out any charge that might be remaining. I have managed to get it back on, but I have to make a connection at the clip where you plug the power button ribbon into the mobo. Also, this is the second time I have had to do this. The computer works fine afterwards...or seems to anyway.
Question 1-I any ideas what causes the computer not to power on when it has sudden power loss?
Question 2-What can I do so that the next time I have a sudden power loss I don't have to take it apart to get it working again?
I like learning computer/electronics repair so be as detailed or technical as you can be to help me learn more about electronics.
