Help with Power Supply
damdam
11:10 PM
win 7
win 7
PSU will work.
MS Windows 7 Ultimate SP1 64-bitAMD A10-4600M6.00 GB Dual-Channel DDR3 @ 798MHz (11-11-12-28)AMD Radeon HD 7660G
AMD A10-4600M
AMD Pumori (Socket FT1)
AMD Radeon HD 7660G
High Definition Audio Device
1600x900@60Hz
Standard PS/2 Keyboard
thx i started it and by my 4thx hard drive the pc will not power up it will power up for 1sec and go off then i have to turn off and on the power supply in the back before i can try agin can a hard drive create the problem or something else.
win 7
win 7
I may be wrong. I had not paid close attention and didn't realize that you have six hard drives.
AMD A10-4600M
AMD Radeon HD 7660G
1600x900@60Hz
I would suggest a 750w or better branded quality PSU. Your graphics card alone requires a 500w minimum add to that all your hard drives. Cpu and opticale drives, not to mention your heatsink fan and additional fans.
Here's a link to a program that will help you get a general idea of what power supply you'll need, This is by no means definitive but you should always get more than required.
Personally I consider the power supply as a very important core piece of hardware not to be skimped on. Hope this will help. Fabe http://extreme.outervision.com/psucalculatorlite.jsp
Windows 7 ultimate 64 bit / XP Home sp3intel Core 2 Duo E8400 3.0ghz8 gigs 1066 OCZ Fata1tyEVGA GTX 580 Call of Duty Black Ops Edition
Asus P5ND bios 1401
Asus 24in LCD's 2MS X2
1920x1080p @60Hz
OCZ 700W GameXtreme
NZXT Apollo
Download 19.83 Upload 0.97
DamDam remember more devices the more power you're going to need you have 6 hdd well hot diggity you're going to need more power that is some major business you got there i think a 750 or 850 watt would be enough could be wrong but i would go that high since you are running more then 2 hdd and also if your running a high end cpu and vidcard such as Nvidia product by all means GET MORE POWER
Enthod Pro Full Tower
Logitech wireless keyboard
Logitech wireless mouse
Cox Cable 100+ mb
IE-10, Chrome, Opera
GPU GTX Gigabyte 970G1
i need to get a power supply for my new pc i am building i need some help.
CPU - i7 920
Motherboard - GA-EX58-UD3R
GA-EX58-UD3R (rev. 1.0) - GIGABYTE
Ram - 3 x 1GB DDR3
GPU - GV-R583UD-1GD HD5830
GV-R583UD-1GD - GIGABYTE
PCIe - 650 ATI Tuner Card
Drives - 6 x 1TB Hard Drive
2 x DVD player
This is the Power supply i have will it work or do i need to get a new one.
XigmaTek NRP-MC651
650w
XIGMATEK
6TB of Hard drives and only 3 gigs of memory is odd!
You will need at least 850 watts of powere.
Windows 7 7600 1 X64AMD PHENOM II X 550 PROCESSOR 3.1 ghzCorsair 4 gig ddr 3ati radeon 3300
ASUS M4A78-TE
Corsair 4 gig ddr 3
ati radeon 3300
ati hd
syncmaster 2033sw
1600X900 60 hz refresh
twin_seagates SATA's 1 TB & 500 Gig, hitachi_slimline 160 gig
antec_550 watt
cooler master GLite
stock_heat sink
20mbs up/ 1.5mbs down
favorite child "stewie"
favorite dog "brian"
Update
all is working know with my old Power Supply 650w i found out that 1 of my Hard Drive was caused the PS not to power up properly i did not know that a Hard drive can cause the Problem, i do have 6gigs of ram sorry posted wrong 3x2gig but i am still thinking of gating a new Power supply here is the one i have my eyes on.
Corsair TX 850 Watt
Antec Earthwatts 750W
Corsair TX750W 750 Watt
win 7
win 7
I'd get the 850w Corsair, or if money was an issue, the 750w Antec. I see no gain the 750w Corsair would give you over the other two. If you can afford it, definitely get a 850w power supply, as it would be more likely to work well.
Windows 7 Professional SP1 64-bitIntel Core i5-2450M @2.5 GHz6 GB DDR3 1333MHzIntel HD 3000
Toshiba P775-S7100
6 GB DDR3 1333MHz
Intel HD 3000
Built-in 17.3" LED; 22" Insignia NS-L22Q-10A
1600x900; 1360x768
750 GB Hitachi
1TB Seagate FreeAgent External
Verizon DSL Speed(Down/Up): 3360 Kbps / 800 Kbps
MSE and MBAM Pro
IE10
PS
Vist Asus.com -- They have a calculator all you do is fill in your devices and it will give you a wattage.
win 7 X64 Ultimate SP1I3770KG Skill F3-14900CL9-4GBXL x 4NVIDIA GeForce GTX670 + Intel 4000
BGC (Bob's Garage Crew)
I3770K
Asus P8Z77-V Deluxe
Realtek HD 5.1 (MOB)
Asus VW224T (1)
SATA Corsair Force GT 2.5" 180GB (System) Sata 3
OCZ Vertex3 120GB
OCZ Vertex 2 120GB 2.5" SATA II
ST31000524AS 1000.2GB
WD15EARS (External)
CoolerMaster 1000 Watt
CoolerMaster HAF X
CPU -- CoolerMaster 520N
MS Wireless 3000 V2
MS Wireless 3000 V2
Cable
Norton Internet Security
IE9
AMI Bios 1805
OC'd 3%
not flaMING you but do you really need 6 tb? of storage,
MS Windows 7 Home Premium 64-bitAMD Athlon II X2 235 Regor 45nm Technology 2....6.0GB Dual-Channel DDR2 @ 401MHz (5-5-5-18)1024MB GeForce 9800 GT (Pny) overclocked at 662
Emachines 1331G
AMD Athlon II X2 235 Regor 45nm Technology 2.7 Ghz
eMachines MCP61PM-GM (CPU 1)
Speakers (Realtek High Definition Audio)
Generic Non-PnP Monitor @ 1280x1024
1280x1024
733GB Seagate ST375052 8AS SCSI Disk Device (IDE)
450W
not sure
fan/air
Microsoft PS/2 Mouse
26mbps
In the interim - have you made sure you've distributed the devices over the rails evenly?
It has four 12v rails, but each only has a rating of 18amps. Overloading a particular rail will give you issues.
An 850W isn't necessary for the devices you have listed, but I'd still opt for one in case you wish to upgrade your GPU / start overclocking etc down the track.
Wattage isn't the most important number to consider however. A good quality PSU with a high AMPS is what you should be looking for.
That TX 850W you linked to fit's the bill perfectly. The only downside is that it's not modular.
Some people do - Full HD rips take up a lot of space ;)
Systems by SmartEyeball
8 Pro x64
i7 3770K 4.6GHz
ASUS P8Z77 WS
x3 Dell U2410 / 58" Samsung
5760*1200/ 1920*1200
Noctua NH-D14
IE, FF, WaterFox
Bloody Big Grin
Are you serious?
I checked the specs on the WD 1GB Caviar Black drive. 8.4W each during read/write operations. that's 50.4W for six, at maximum.
I think that the Xigmatech unit would have plenty of margin even if the CPU is seriously overclocked, as long as "damdam" doesn't upgrade to a 300W graphics card (GTX480, Radeon HD3970).
I see that he (/she/it) is going with 6GB of RAM, which is more like it.
Windows 7 Pro X64 SP1Intel Core I7-3930k16 GB Gskill DDR3-2133eVGA GTX680
homegrown
Intel Core I7-3930k
Asus P9X79 Pro
eVGA GTX680
Creative X-Fi Titanium
As PA246Q
1920 X 1200
Corsair Force GT, 120 GB
WDC 1.5TB Caviar Black
PCP&C Silencer 750 Crossfire
Silverstone FT02
Noctua NH-D14
cheap Logitech USB
Microsoft Intellimouse Explorer (old optical) USB
6Mb cable
Pioneer BDR-205
Samsung SH-203B
Monsoon 5.1 speakers
ok this is what i got on the 650w XigmaTek NRP-MC651
and i did a stress test for 3H (Prime95) all good no error or power failure
HAF 932 2x120mm fan 1x80mm fan
cpu i7 920 OC:3.4
win 7 64bit
GA-EX58-UD3R
Ram: 6gigs
HD 5830
TV Tuner Card
2 x DVD player
2x1TB Hitachi
2x1TB WD Caviar Green in RAID 0
and this is the Power Supply i will be Purchasing this week Corsair HX Series 850 Watt they have it for 185$ i will get it for 144$ and this one is modular and the other one was not thx smarteyeball if u guys see any other good Power supply or better than the xs850 my local stores are Micro Center and Fry's no more then 180$ haha. i will need something around 850w because i will do some more upgrade in the future.
win 7
win 7
