dual monitor problem (primary monitor disappears)
hydrarulz
1:18 AM
I've searched some forums and while i have found all sorts of dual monitor problems i haven't found this one.
I have a MSI M670 laptop ( with nvidia 6100Go graphics card ) and a Samsung SyncMaster T240HD. I always connected my monitor with a VGA cable on my windows xp and everything worked fine.
After i've installed Windows 7 when i connect the monitor to my laptop automatically the laptop monitor is disabled and the Samsung becomes the primary display.
If i press windows_key+P Computer Only is selected and whatever i select from the list ( duplicate, extend, projector only ) nothing happens and Computer Only is always selected.
In the Nvidia panel under the "Set up multiple displays" option after i connect the Samsung it becomes the only option so i cannot revert to my laptop display whatever i do.
Rigurous Display Detection does not help at all.
Any ideas ?
Have you been to multiple displays option in nvidia control panel and selected them both?
Windows 7 Professional 64-bitIntel E8400 3GHzKingston PC3-10700H 4GbXFX Radeon HD 5850 BlackEd.
self built
Intel E8400 3GHz
Intel DX48BT2
Asus Xonar DG
2x Samsung SM-T220HD 22"
1680x1050 on two monitors
OCZ Vertex 2 120gb 3.5" (OS)
Seagate Momentus XT 500gb
Samsung F3 1Tb (games)
2x Samsung F1 1Tb
Thermaltake ToughPower 850w
Thermaltake Armor
Scythe Mugen II
Microsoft Comfort Curve USB
Razer Diamondback 3G
i cannot do that because when i connect the second monitor, the first one disappears from the list and only the second one is present.
