best battery to give longest battery life?
  1. Posts : 422
    windows 7 64 bit
    hi guys, i want to get a battery for my acer aspire 5315 laptop that will give me the longest possible time on the go.
    what will i need 4 cell, 6 cell 12cell? which one?
    ps. and i know that i can change powerplan and tweak some settings but i think a new battery would be best.
  2. Posts : 9,582
    Windows 8.1 Pro RTM x64
    Assuming that they are all designed to fit your laptop, you need to look at the ratings. Basically, you want the one with the greatest Ah (ampére-hour) as that should last longest. Although this usually means the battery with the most cells, it doesn't always follow. Check their specifications.
  3. Posts : 19
    Genuine Windows 7 Ultimate 64-Bit
    12 cell
