best battery to give longest battery life?
AussieGuy92
i am Awesome
Pro User
12:31 AM
Commonweath of Australia
hi guys, i want to get a battery for my acer aspire 5315 laptop that will give me the longest possible time on the go.
what will i need 4 cell, 6 cell 12cell? which one?
ps. and i know that i can change powerplan and tweak some settings but i think a new battery would be best.
windows 7 64 bitintel core i5 3.30GHz Quad Core6gbAMD RADEON HD 6450 1GB Dedicated
HP Pavilion p6795a
windows 7 64 bit
HP
6gb
ATI HIGH DEFINITION SOUND
LG
16:9 Hd
1TB
Fan
Wireless
HP wireless keyboard and mouse
fast enough
Beast Of A Machine!
Assuming that they are all designed to fit your laptop, you need to look at the ratings. Basically, you want the one with the greatest Ah (ampére-hour) as that should last longest. Although this usually means the battery with the most cells, it doesn't always follow. Check their specifications.
Dwarf Dwf/11/2012 r09/2013
Windows 8.1 Pro RTM x64
ASRock Z77 Extreme4-M
Iomega 1.5TB Ext USB 2.0
WD 2.0TB Ext USB 3.0
Gigabyte IF233
Avast! 8.0.1497
IE 11
12 cell
Genuine Windows 7 Ultimate 64-BitOverclocked Intel® Core™i7 975 3.86GHz12Gb (x3 4Gb)Dual 2GB GDDR5 ATI Radeon™ HD 5970 CrossfireX™
Dell Alienware Area 51 ALX
12Gb (x3 4Gb)
Creative Sound Blaster X-Fi Titanium
Dell Ultra Sharp
1-2TB RAID
1-1.5TB RAID
Logitech Gaming Keyboard
Logitech Gaming Mouse
12 MBPS Broadband
