Where can I find a replacement power light?
Megaman0
9:10 PM
I have an ASUS essentio and the power indicator light broke. Where can I find a decent replacement?
It was connected through a 4 pin molex.
Thanks! :geek:
Windows 7 64bitIntel Core 2 Quad Q8300 / 2.5 GHz8GIG DDR-2Integrated Intel G45/G43 Chipset
Asus Essentio CG5270-BP004
Windows 7 64bit
P5QL-VM EPU CG5270
8GIG DDR-2
LG-W2361VG
Thanks! :geek:
sorry I cant help but have you done a google for that.?
HP Pavillion dv-7 1005 Tx
Win 8 Release candidate 8400
[email protected]
4 gigs
Nvidia 9600M
HD built-in
17" Wxga
none
45Mb down 5Mb up
you meant the led on the case front? thats usually connected directly to the motherboard headers alond with the power switch/reset button etc
Win 10 Home Premium 64 BitI7 5930K @ 4.516GB Kingston Hyper X Fury DDR4EVGA 980ti SC + ACX 2.0
I7 5930K @ 4.5
Asus X99 s
Onboard
ROG Swift PG278Q
Kingston Hyper X 250gb SSD
Samsung 2TB mechanical
Corsair RM 850
NZXT H440 Red
Corsair H100i GTX
Razer Reclusa
Logitech G5 Gamer
34mb
Eset Smart Security
ouch! can you confirm if the power light is seperate from the motherboard? and if so, it would be easier to find the light if we know its product number
Windows 7 Ultimate 32xIntel Core 2 Duo T6600 @ 2.2GHzDDR2 2GBIntel Integrated GMA X4500MHD
Dell 1440
Dell 0K138P
DDR2 2GB
WXGA 14.1" Gloss
320GB SATA HDD
Windows 7 Profession 64-bitIntel Core i7-860 QuadMushkin 4x2Gb PC12800Gigabyte GTX260 896Mb
BrightWorks Systems B4
Gigabyte P55-UD4P
Integrated 7.1 HD Dolby
2 Samsung 2220wm-HAS 22"
1680 x 1050 | 1680 x 1050
WD HE 1Tb
Corsair TX-750W
Ultra M998
OEM
MS Wireless Comfort 5000
MS Wireless 5000
Cable and pretty darn fast
