Windows 7: Problem setting up second display
18 Sep 2010   #1
Internet Badass
Windows 7 Home Premium 64 bit
I am trying to set up a duo monitor display with an old dell m782 monitor I got for free from my school. My computer detects that its there, but there is no picture on the monitor. When I press the menu button it says MONITOR IN POWER SAVE MODE ADJUST WITH PC. in a blue and grey box that stays in one place. Ive tried the Self-Test Feature Check on the dell online manual
Documentation
and it still says the power save mode. This is on my desktop too, which in my system specs is before the /
18 Sep 2010   #2
Anak
Win 7 Home Premium 64bit Ver 6.1.7600 Build 7601 - SP1
Hi! IB,
Do you see a blinking green light on the monitor indicator?
Can you get to the OSD and reset?
From the documentation:
Quote:
Power Management Modes
If you have VESA's DPMS compliance display card or software installed in your PC, the monitor can automatically reduce its power consumption when not in use.
Even though your PC can see it you may not have the proper card or software. Did windows offer to PnP to set it up?
18 Sep 2010   #3
Internet Badass
Quote   Quote: Originally Posted by Anak View Post
Hi! IB,
There is a blinking green light, but i cant get to the osd. Windows didnt offer to set up anything it just installed the driver.
18 Sep 2010   #4
Lemur
If you swap monitors does it display?
18 Sep 2010   #5
Anak
Ib,
I did a search on the m782 at the dell site, and from what I've been reading; you might be better off trashing the monitor.
  • Best I can tell it came out in 2001-2002, and was designed to go up to win XP.
  • The driver I found for it is only 115KB.
  • The MS PnP drivers seem to work better than Dell's.
  • It has problems running on a machine that has more than 512MB ram
There are 'bout 23 threads with all kinds of problems See:
Search - Dell Community
Driver site:
Drivers and Downloads
Sorry to be the bearer of bad news....
19 Sep 2010   #6
Anak
Ib, there may be some hope.
I've been researching the m782, and everywhere I've looked I kept running into that the problem involves the hardware of the monitor that involves power management.
One reference here:
https://bugzilla.redhat.com/show_bug.cgi?id=445110
Here I may have found a workaround. Post #6 here:
ATI R128 driver and Rage Mobility M4 - Ubuntu Forums
You may be able to apply his workaround to your drivers and card.
Hope this helps......Anak
Search this Thread:
Advanced Search
Error when setting Display information about previous logon on Wins 7
We recently try to deploy a GPO on our network to show previous logons during user logon. The setting is located in Computer Configuration| Policies | Administrative Templates | Windows Components | Windows Logon Options | Display information about previous logons during user logon = Enabled. Our...
General Discussion
Need help setting Excel to display as I would like
A problem I have had for a few years now and have not been able to figure it out so I put up with it. When I use Excel 2010 and open more than one worksheet I have troubles finding each worksheet, is there a way to have Excel display a tab for each worksheet so I can switch back and forth easier. ...
Microsoft Office
When I re-dock, my display setting (the 2nd monitor) is missing.
I am encountering a different issue since the attempt to migrate the user folder to a different drive. I am on a laptop connected to two monitors via docking station. When I re-dock, my display setting (the 2nd monitor) is missing. I keep having to extend the main monitor to the 2nd display each...
Graphic Cards
Display setting problem with LinuxMint13 and VMWare Player
G'day, I have several versions of LinuxMint (9, 11 and 12) as well as a few other distros running perfectly at 1920 x 1080 resolution (my native resolution) under VMWare Player. I have never had a problem specifying this resolution, without or without the VMWare tools installed. Recently I...
Virtualization
setting up dual display
I am new to duel monitor setup so take it easy on me guys. Ok i was trying to connect a secondary monitor. As I have never done it before, so I watched a video tutorial on cnet. According to that I connected the second monitor to the computers on board VGA port but I am not getting any display...
Graphic Cards
Troubleshoot on VM Display setting
Hi, at first I wasn't sure were to place that thread. So I'm sorry if its wrong here. I need to know were I can change the "Hardware Beschleunigung" (I guess its called "hardware acceleration" or "hardware speedup"). I hoped to find it within the display settings > advanced > troubleshoot...
Virtualization
