USB 2.0 to IDE/SATA Converter cable problem
  1. Posts : 27
    I have an old Hard Drive that I backed up a lot of my music on but when I plug the converter cable from the Hard Drive into my laptop (I only want to transfer my files from the Hard Drive to my laptop) I hear the noise windows makes when it recognises something but the Hard Drive doesnt show up in My Computer (its a seagate 320 gig HD). Does anyone know how to fix this?.
  2. Posts : 9,537
    Try assigning a drive letter to the seagate so windows 7 can recognize it. IMHO
  3. Posts : 27
    How do I do that exactly. I know I must go to Disk Management. I get there and I see the HD (It shows up as disk 1-unknown-not initialized). When I try to initialize it (not sure if I have to do that) a box comes up saying Disk not ready.
  4. Posts : 9,537
    Have you updated the seagate driver?
    Will see if I can find one and get back to you!
    http://www.seagate.com/www/en-us/support/
    see if you can find your driver there!
  5. Posts : 27
    Support | Seagate
    Checked on there. Seems as though the HD I have dont have no additional drivers. Hmmm. This is weird.
  6. Posts : 9,537
    Read this post and pay particular attention to Brinks response in post #4
    Can't change hard drive letter to needed letter
  7. Posts : 2
    Windows 7 Home Premium
    Im having the exact same problem, did you find a solution?????
  8. Posts : 9,537
    Take a look at this thread and make sure you both have it hooked up right.
    Transend USB 3.0 PCI Card
    post back and if necessary will get more help coming your way.
  9. Posts : 2
    Hey, Ive tried all of than at....any other ideas?
  10. Posts : 9,582
    Windows 8.1 Pro RTM x64
    Faulty interface? One of my older external HDDs would occasionally stop working or would only work intermittently. This problem was resolved by replacing the enclosure.
