Battery Problem
  1. Posts : 5
    Battery Problem
    Since I installed Windows 7 RC1 on my PC, I started having a problem related with my Sony Vaio VGN-FE41S battery. When I insert it, my computer displays an error saying that the battery is incompatible and the computer will hibernate because of that.
    Any solution?
  2. Posts : 9,582
    Windows 8.1 Pro RTM x64
    Hi Reckoner and welcome to Se7en Forums
    This sounds like a power management driver issue. What does your laptop actually do when the battery is installed (apart from displaying this message)?
  3. Posts : 5
    Thanks for the welcome message. :)
    Well, after I put the battery, Windows 7 recognize it but that message appears and nothing more. After the message, my PC just goes to hibernate mode.
  4. Posts : 9,582
    Did you install W7 with the battery inserted, and was the battery charged when you did so?
  5. Posts : 5
    No and no.
  6. Posts : 9,582
    OK. Try reinstalling W7 with the battery inserted (and charged).
  7. Posts : 5
    That would take much time and patience. Is there any other solution?
  8. Posts : 5
    Forget! I just solved the problem reinstalling the power management drivers. Thanks, anyway!
  9. Posts : 9,582
    I'm pleased that you have managed to solve your problem. I note that it was, as I suspected, an issue with the power management drivers.
  10. Posts : 1
    How to reinstall Power Management Drivers?
    Reckoner,
    I have the same problem, where did you did you find the correct driver?
    I tried to reinstall the drivers from Sony without success.
    Thanks,
    Vítor
