Keyboard Problem (Ctrl and Shift keys don't work correctly)
nekov4ego
Power User
9:14 AM
Bulgaria, Europe
Hello everyone. Today my shift and ctrl keys stopped working correctly... it happened while I was playing and later when I tried to change the language using Alt + Shift. I checked if Sticky Keys and other similar options weren't turned on by accident, but they weren't.
And after some time spent in trying to fix the problem I opened the On-Screen Keyboard and noticed that when I use my Ctrl key, Shift is pressed automatically as well (it's just what On-Screen Keyboard says). The same thing happens when I press Shift, then the Ctrl key "presses itself". It so happens that all four (left and right shift, and left and right ctrl) keys are pressed at the same time, when I press just one of them.
Does everyone know where the problem could be from and how I can fix it... it's really annoying, I can't use any of the combinations like Ctrl + V, Ctrl + C, Ctrl + A, etc. The problem started while I was playing Assassin's Creed; I sometimes hear sounds like too-much-buttons-pressed while I play it, but I've never had this problem until today. I have no idea what it could be, I tried everything I know.
If it helps, the problem is still there while I chat or surf the web through Asus Express Gate, when the windows isn't running at all.
PS: Sorry if I used strange phrases or words, I am not a native English speaker.
Microsoft Windows 7 Ultimate x64 (Build 7601 ...AMD Phenom II X2 555 @ X4 B55 (3.2Ghz, 2MB L2...4GB (2x2GB) Corsair DDR3, 1333MhzASUS ENGTX560, DirectCU, 1GD5
Microsoft Windows 7 Ultimate x64 (Build 7601 SP1)
AMD Phenom II X2 555 @ X4 B55 (3.2Ghz, 2MB L2/6MB L3 Cache)
ASUS M4A785TD-V Evo
8-Channel HD Audio
Philips 226CL2SB
1920x1080p
500GB Seagate, SATA2, 7200rpm, 16MB/s
Corsair TX650 v2
90mbps Fiber Optics
See if pressing both 'shift' keys at the same time, gets your keyboard operating correctly again.
Windows 7 Ultimate 32bit SP1
INTEL/D975XBX2
ATI Radeon HD 2600 Pro
Samsung SyncMaster 914v
1280 x 1024
One is not connected
Rocketfish 700 W
G.Skill Gigabyte Chassis
Standard PS/2 Keyboard
Microsoft PS/2 Mouse
DSL
Avira Internet Security
IE 11
ATI HDMI Audio
Nope, I read it somewhere and I tried it... still, when I press both shift keys, the ctrl keys press themselves. I can't press ONLY the shift keys together.
ASUS M4A785TD-V Evo
8-Channel HD Audio
Philips 226CL2SB
1920x1080p
Corsair TX650 v2
90mbps Fiber Optics
Have you also tried pressing the shift key 5 times in a row or holding it down for about 8 seconds?
INTEL/D975XBX2
1280 x 1024
Rocketfish 700 W
DSL
IE 11
ATI HDMI Audio
hello and welcome :)
now is the keyboard usb connected or ps2 connected? have you checked all the settings in keyboard settings to how you require them ? go to device manager and uninstall the keyboard driver pull the connection (usb or ps2) now reboot as machine is rebooting put the connection back in and wait for windows to install the drivers (make sure you are connected to the web in case windows need to access the internet for drivers) .
also have a look here for any help with common windows problems Microsoft fix it center>>
Microsoft Fix it Solution Center
Operating System : Windows 7 Home Premium Edi...Processor : Intel Core 2 Quad Q8300 @ 2500 MHzPhysical Memory :8GB Corsair4x 2GB 800MHz C5 ...Video Card : XFX 6700 AMD
packard bell IXTREME M5722
Hard Disks : WDC (1000 GB)
(X 2) KINGSTON SSD NOW V 30GB
XFX ProSeries 550W PSU
PACKARD BELL IXTREME
Gigabyte Aivia K8100
chrome dev
Version : P01-A1
Date : 08/31/2009
That would be the Sticky Keys' shortcut? It was working until today... now when I press Shift five times or hold it down for 8 seconds, it is like pressing/holding Ctrl key as well, and no shortcut appears.
@brianzion
The keyboard is PS/2 connected, and I have also tried re-installing the drivers, Solution Center wouldn't find a problem, it isn't an actual problem for the system, it is a problem for me. Windows wouldn't mind if Ctrl is stuck to Shift.
Is there a way to check if it is a hardware problem apart from trying another keyboard (which I am looking forward to; I'll try it as soon as I get the chance).
ASUS M4A785TD-V Evo
8-Channel HD Audio
Philips 226CL2SB
1920x1080p
Corsair TX650 v2
90mbps Fiber Optics
tried this
Right Shift for eight seconds to Turn Filter Keys on and off ????
chrome dev
Version : P01-A1
Date : 08/31/2009
does this help??
chrome dev
Version : P01-A1
Date : 08/31/2009
No, if I press Shift, Ctrl key is pressed and for that reason no shortcuts work. I tried all those options -- Sticky Keys, Filter keys, Mouse Keys, etc. -- but nothing fixed my problem. If there's a particular option in some of the Keys options that can somehow "lock" a key to another so that every time you press one of them, the others are pressed as well, it could be the solution.
I don't know how Express Gate works and if it's connected to the windows, but if it doesn't use windows drivers, the problem should be the keyboard itself.
ASUS M4A785TD-V Evo
8-Channel HD Audio
Philips 226CL2SB
1920x1080p
Corsair TX650 v2
90mbps Fiber Optics
yes you may have to change the keyboard at least try a new one to see if that solves it if you use the keys for gaming( pressing the keys fast and hard) im sure the little boards underneath inside wont last long.
chrome dev
Version : P01-A1
Date : 08/31/2009
Thanks for all suggestions, I will try another keyboard as soon as I can. It won't be a big surprise if the one I am using is the reason I'm having problems, for it is about six years old, it is my first and only (if we don't count the laptop) keyboard. I love it, and I love the fact I haven't had any problems with it until now. I am really used to typing on it, because six years isn't a short period of time.
I will write when I fix the problem, thanks for everything... and if you think up something else, you are more than welcome.
ASUS M4A785TD-V Evo
8-Channel HD Audio
Philips 226CL2SB
1920x1080p
Corsair TX650 v2
90mbps Fiber Optics
Have you rebooted since this key got stuck?
INTEL/D975XBX2
1280 x 1024
Rocketfish 700 W
DSL
IE 11
ATI HDMI Audio
Yes, I have... after I tried re-installing the drivers. Everything is fine now, it fixed itself while playing AC2 lol. I don't know how and why it happend.
PS: How do I make the topic "solved"?
ASUS M4A785TD-V Evo
8-Channel HD Audio
Philips 226CL2SB
1920x1080p
Corsair TX650 v2
90mbps Fiber Optics
well done ( i would still get a new keyboard now though );)
chrome dev
Version : P01-A1
Date : 08/31/2009
click the triangle at the top of page and type solved and a moderator will do the rest:D
chrome dev
Version : P01-A1
Date : 08/31/2009
Thanks for everything. Now I know where to ask when I have problems with my PC.
ASUS M4A785TD-V Evo
8-Channel HD Audio
Philips 226CL2SB
1920x1080p
Corsair TX650 v2
90mbps Fiber Optics
chrome dev
Version : P01-A1
Date : 08/31/2009
I have exactly the same problem...
The difference...i bought a new keyboard and i have exactly the same simptoms :(
Any help besides buy another keyboard ?
Windows 7 Enterprise 64bits
sorry to hear you have problems explain whats happening and what board you have :)
chrome dev
Version : P01-A1
Date : 08/31/2009
Ok, I found this topic by google-search and I have the same problem and unable to fix it.
I don't know how it started, I do not play any online-games but it happened nevertheless.
I am using a Toshiba-laptop and I really don't know a thing about computers.
I'm just about to throw the bloody thing through the window out of frustration.
Apparently the solution from what I understood is replacing the keyboard, but since it's a laptop, I don't think that's possible right?
Or should I reboot? How does that work? Won't I lose everything? I've never done that before and I'm scared I will lose everything.
I'm absolutely desperate to fix this problem and to know how I can prevent it in the future.
MX-DIF
toshiba laptop
MX-DIF
