External IDE drive problem
Page 2 of 2 FirstFirst 12
  1. Posts : 5
    Windows 7 Home Premium 32bit
    - my system restore points only go back about 3 days. (how do I change that?)
    - it is listed in device manager, but cannot rollback as there was no driver update done. tried the "update driver" option but it says it is up to date
    - chipset/IDE/SATA/RAID/AHCI driver or BIOS setting - unlikely as it was working before when I had Vista on the same mobo (not XP as I first wrote)
  2. Posts : 2,259
    W7 Professional x64
       #12
    It's not hardware, as you can use the drive fine in linux PE. It's a windows issue for sure. Try running from the command prompt "SFC /scannow" a couple of times. If that comes up with nothing, you may want to try a repair installation.
  3. Posts : 5
    I ran SFC several times, found no issues.
    Then I booted from the Windows CD and tried a Repair. It keeps telling me to unplug any cameras or external disks and restart. However nothing is connected to the USB ports except the mouse. What else to do?
    If I want a clean install, do I delete the current Windows directory?
  4. Posts : 2,259
    W7 Professional x64
       #14
    For a clean install, back up your important files onto CD/DVD or whatnot, and wipe the drive with zeros:
    SSD / HDD : Optimize for Windows Reinstallation
