i need help with a usb problem
dumle29
Banned
8:28 AM
Hi well actualy its my friend who needs help but im helping him(without luck)
he has a usb pen that when plugged in to a computer isnt recognized
previously we cut of the end of the usb device and it worked fine. then there was a pice of pcb stiking out with an smd led on it and we decided to cut that off too. it worked fine for a month or so but now it wont be recognized
any idea?
Windows 7 + windows xp
HP s5130sc
Since it has been modifed twice, it would appear it has been damaged and the reason it doesn't work.
My Own Build
Intel i7 6700K
ASUS ROG Maximus VIII Hero
16GB Corsair Dominator
Intel CPU Graphics
RealTek
27" Dell S2719dgf
2560X1440
2 TB drive for backup
EVGA Supernova 750G2
BeQuiet Silent Base 600
Deepcool Captain 120EX
Microsoft Wireless 2000
Microsoft wireless
100 MB/sec (Cable)
Edge/Firefox
I wholeheartedly agree!
If you have sensitive data on there then why may ask would you risk it 'snipping bits off'?
USB memory is a dime a dozen these days too
Windows 7 Ultimate SP1
any idea?
Purchase a new drive. Their is no way to know if all your "snipping" hasn't caused some kind of defect inside of the drive on it's PCB board.
Fabe
Windows 7 ultimate 64 bit / XP Home sp3intel Core 2 Duo E8400 3.0ghz8 gigs 1066 OCZ Fata1tyEVGA GTX 580 Call of Duty Black Ops Edition
Asus P5ND bios 1401
Asus 24in LCD's 2MS X2
1920x1080p @60Hz
OCZ 700W GameXtreme
NZXT Apollo
Download 19.83 Upload 0.97
any idea?
Are you serious? unbelievable
Windows 7 Ultimate (x64) SP1Intel 3770k 4.6GHz8GB (2x 4GB) Crucial BallistixSapphire 7950 (1060/1600)
tw33k
Intel 3770k 4.6GHz
ASUS Maximus V Formula
On Board Realtek HD Audio
27" Acer B273HU (via HDMI)
2048 x 1152
Crucial M4 128GB
2TB WD Black
1TB Samsung F3 SATA
1TB WD Elite External
2TB WD USB 3.0
Corsair AX750 Gold
Corsair Obsidian 800DW
Corsair H100 (2x AP-121/2x UK-3000 push/pull)
Microsoft Wireless 5000
5mb/s
Logitech z-2300 2.1 speakers
Lamptron FC-5 v2
any idea?
Fabe
Spot on advice.
Windows 7 Ultimate 32 bitIntel(R) Pentium(R) 4 CPU 3.00GHz2.50 GB RAMNVIDIA GeForce 7600 GS
Home built
ASUS P4P800-VM Motherboard Chipset: Intel 865G + ICH5
2.50 GB RAM
SoundMax Integrated Digital Audio (Chip)
ViewSonic VX 1962 wm
1680 X 1050
Seagate Barracuda 7200.10 80 GB
ST380215A ATA Device 18.6 GB
Western Digital "My Book" external hard drive 750 GB
Fan based
Microsoft Comfort Curve Keyboard 2000 v10 USB
Logitec optic USB
3.01 Mb/s download 0.64 Mb/s upload
well since we had the hardware me and my friend had a little advantage there.
we have now fixed it ( and added a 5mm led :D)
some sort of metal cylinder that we think was a capactior but suspected that it might not have been had gotten loose from the pcb (no were near the snipping)
the reason why we got data caught on it was because when we snipped it we backed it up the we snippe one bit of (just a wire bridge leading nowhere) then we tested and it worked fine (wire bridge meaning a long strip of pcb doing nothing other that making it longer)then we snipped of another wire brige with a smd led on and it still worked. then a month later (he used it and got new data on that we didnt back up) it just stopped worked. so, no we were not so stupid to snip in it without backing it up (it was a 2 gb pen so we didnt really care if it broke). how ever, everything is fine and functional :D and we got the data. (and reduced the size of the usb pen with 2 cm in length)
HP s5130sc
once i accidently kicked on my usb - Sandisk Cruzer Contour, it folded 90 degree. After open, make straight and soldered back, still KO, luckily with the help of microscope at work and Metcal Solder Station, able to trace a tiny broken track, after resurrection, it is now back to 100% performance.
dumle29 wrote
"some sort of metal cylinder that we think was a capactior"
that should be a crystal oscillator for clocking.
Windows 7 Pro 32 bitC2D P7450 @2.13GHz2GB
Lenovo Ideapad Y450
C2D P7450 @2.13GHz
2GB
yeah thought of a crystal thingie. he ok another of my usb pens are right now at a 45 degree angle of the usb (have had the time to undsolder it yet guess ill do it now :D
HP s5130sc
