DVD RW problem(E:\Application not found)
  1. Posts : 3
    Windows 7 Ultimate x32
    Hi!Im new to this forum.I was looking for solution for my DVD drive.
    My computer was turning on and off itself(it still does),so i opened it and clean it.I was bent my processor pins,so when i tried to turn it on,its starts beeping.So i fixed it.Now it turns on,but now my DVD drive dont work!!
    When i insert DVD or CD in,nothing happens and when i double click on it says"E:\Application not found".It says even if theres nothing in it(DVD,CD).Theres no"explore"or anything.I really need it but i cant find solution.
    Can anyone here help me??I tried with regedit and update,even reinstall,but nothing works.
    Thanks!
  2. Posts : 28,845
    Win 8 Release candidate 8400
    Thanks!
    Ugh, never take your CPU out.. I suspect your dvd drive isnt plugged in correctly given you experience when "cleaning" you cpu.
    Ken
  3. Posts : 2,009
    Windows 7 Ultimate x86
    Ken is right! You might have inadvertently dislodged a cable or even worse caused some irreparable damage due to static electricity.
    First step would be to boot into BIOS and check if the drive still shows up there.
    -DG
  4. Posts : 3
    Ken
    thanks for reply.
    yes,i made a mistake,i wont do it again.OK,I will check cables.Thanks
    -DG
    But everything works well except DVD drive.Yes i tried it,it shows up.
    Would it be the best to take it to the service?I still have warranty on it.
  5. Posts : 5,056
  6. Posts : 3
    Tried both solutions.Deleted mousepoint2 on regedit but now it says"insert a disc".
    And i tried 2nd solution yesterday,didnt work.
  7. Posts : 1
    Windows 7 64 bit
    This reply is rather late. But i faced the same error "E:\ Application not found" when i clicked on DVD drive icon today 23 november 2015. I ran CCleaner--Registry---Scan for issues--Fix all selected isssues. And it solved the problem.
