Windows 7: Problems connecting wireless printer
06 Nov 2010   #1
Whippet
windows7 home premium 64bit
I've a Dell Inspiron 1750 & a Canon MP560: they're next to each other on my desk.
I've been through the printer installation & select the network & wireless option, but the Dell can't find the Canon.
Trying from the other end, I go through the connection option on the Canon & when it can't find the Dell automatically it asks for the access point name.
I've tried entering the SSID - that didn't work. So I tried the network key (being careful with upper/lowercase) but that doesn't work either. The printer can't find the Dell.
Both the Dell & the printer happily find my wireless router, so the wireless 'thingies' must be working OK.
What the heck am I doing wrong?
I'd be glad of any help.
Thanks,
Jackie
06 Nov 2010   #2
TVeblen
Hi Whippet. Welcome to the Forum.
First, make sure that the wireless printer is set up correctly (sorry if this is redundant).
On the printer setup settings, make sure the SSID is correct, the router's security protocol, and the long encryption key - all in the right upper/lower case.
Check to see that the "Wireless Connection" icon is illuminated and that you have some bars.
Next, in Windows, click on the Network icon in the taskbar and open "Network and Sharing Center". On the top line is "View your basic...", and click on "See Full Map". See if a wireless device is showing up there.
If it is then you have no network problem, just a driver installation problem. Let us know and we can take it from there.
Also: are you installing the printer driver from the printer CD or from a download?
06 Nov 2010   #3
DMHolt57
Most wireless printers require the software be installed first and then the USB cable attached to a computer for the internet connection sharing to be setup.
06 Nov 2010   #4
bassfisher6522
Windows 7 Ultimate 64 bit
Quote   Quote: Originally Posted by DMHolt57 View Post
Exactly right, once that is done then you can unplug usb cable and print wirelessy to your hearts content.
07 Nov 2010   #5
Whippet
Thank you for the replies.
Before I start to check step by step what you suggest, I'd just like to ask how this wifi connection between PC & printer is supposed to work.
Do the PC & printer talk directly to each other, or do they communicate to each other through my internet router?
I need to have a vague understanding of how this wifi connectivity works.
Thanks for your welcome to the forum - it's full of real gems for a W7 newbie.
Jackie
07 Nov 2010   #6
pebbly
Hi Whippet, welcome to the forums , have a look at this link How Does a Wireless Printer Adapter Work? | eHow.com it may help you to understand the principle of wireless printing easier
07 Nov 2010   #7
Whippet
Oh amazing!!! I've just done my first wireless print
You'd think I'd discovered the wheel, I'm so happy.
I've been trying for days & days to do this, without understanding that the PC & printer talk to each other through my router.
Eureka
Many thanks to all who helped.
Jackie
Connecting to Wireless Router keeps connecting and disconnecting
Hello Guys, I am having trouble with my wireless connection. It was working fine till a couple of days back and then started acting up. Let me explain the problem in detail. System connects to the router. It shows full signal. After 10-15 seconds the wireless gets disconnected. After that the...
Network & Sharing
Problems installing Canon MG6220 Wireless Printer in Win 7 x64
Bought this printer yesterday. After setting up the printer and installing the drivers from Canon I am presented with a message that the printer cannot be found on the network. I set up the wifi connection on printer, it found the access point and stated it was connected. The wifi light was on the...
Network & Sharing
Problems installing wireless printer on home network
I posted a thread previously, but still no luck -even took my computer to a repair store. I am on a Verizon FIOS wireless network. We have both a Toshiba and Sony computer. I downloaded the latest drivers for my HP Photosmart 6280 printer and was able to successfully install my printer...
Hardware & Devices
Wireless Printer Problems
:zip:Hi All I having a problem with my wireless printer I have Win7 32bit installed, printer is Brothers MFC-845CW, router is NETGEAR WNDR 3700 , I have checked the printer setup and printer connects to the router OK but when I try to print I get a error message saying something like (...
Network & Sharing
Wireless printer problems
I have a Lexmark x4530 printer using a Linksys Wireless G router; a HP laptop. Had some router to laptop issues and probably changed some settings. I cannot get the printer to print even after changing all settings back to factory, resetting the router. After using installation disc and cable,...
Hardware & Devices
Installing HP 2710 wireless printer problems - offline?
I did a clean install of Windows 7 enterprise on my Sony Vaio. I have an HP 2710 wireless printer that worked fine with Vista. I have tried installing it using the drivers from hp.com & using the 'find wireless' printer function found within Windows 7. It had no problems with either method with...
Hardware & Devices
