(Code 24) - Power Controll Error - Help
  1. Posts : 61
    Windows 7 Home Premium (x64) (build 7600)
    Hey all, I have this problem and get this
    "This device is not present, is not working properly, or does not have all its drivers installed. (Code 24)"
    I tryed going to drivers and it says under "Current Status" saysStatus: Stoped and I try clicking Start but gives me yet another Error - "The system encountered the following error while attempting to start the service - The system cannot find the file specified"
    any help welcome, my power supply is - Antec true power quattro 1200 watt
    Thanks in advance all.
  2. Posts : 3,139
    Take a look in Device Manager and see if your device is listed. Do you know what device the message is referring to?
  3. Posts : 61
    Thanks for the reply and yes it shows up in device manager but has the triangle with the ! in it and next to the Power Controll
    Edit - Oh and its with in the device manager as in "None-Plug and Play Drivers"
  4. Posts : 3,139
    Can you provide a screen capture of this?
    (oh, and it's "non-plug and play", but not a big deal at all)
  5. Posts : 61
    Here
    Attached Thumbnails Attached Thumbnails (Code 24) - Power Controll Error - Help-error.png
  6. Posts : 3,139
    Are you running cyberlink powerdvd?
  7. Posts : 61
    CyberLink Blu-Ray
  8. Posts : 3,139
    I think if you uninstall this program, the problem may resolve itself. If it does, there are alternatives to play blu ray.
  9. Posts : 61
    ye I have reinstalled windows and it has seem to have gone
