rtl8187, wireless problem
Page 1 of 3 123 LastLast
  1. Posts : 13
    windows 7 32 bit
    hey, my wireless receiver on my stationary computer does not work with windows 7..
    i installed 7 today and had internet on my vista version befor installing.
    on the windows 7 version my wireless receiver(rtl8187) did not work, i need updates i think... but i have been all over the internet and only found updates up to windows xp!
    and it did work on my win vista so why not on win 7??
    please neeeed help
  2. Posts : 6,305
    Hi, welcome to the forums :)
    Try downloading from Here and select the B version. You'll find that it has support for Windows 7.
  3. Posts : 13
    windows 7 32 bit
    THANKS alot!
    just wondering, i had to download this on my laptop as i obviously do not have internet connection on my stationary, and therefore i don't have winrar on my stationary either, can i just move everything (winrar and the update) to my stationary from my laptop using a USB?
  4. Posts : 6,305
    USB is 1 quick option. Connecting to the router via an Ethernet Cable is easier if the router is close enough.
  5. Posts : 13
    windows 7 32 bit
    okey, i've transferred and everything. installed it now but it only installes some sort of a wlan utility program that really does'nt do a single thing...went to update device drivers and found my device and pressed update driver software, still same prob, win 7 can't find any updates..what to do???
  6. Posts : 525
    windows 7 ultimate 64bit
  7. Posts : 13
    windows 7 32 bit
    kword88 said:
    i've tried everything now, tried every driver in every site, but noone works...i install them and nothin happens, AT ALL!!
    really getting on my nerves now, anyone who had this problem can tell me exactly wht they did??
    and i do not have internet connection on my stationary, as many other with similar problem seem to have, I have to download on this pc and transfer to my other pc.
    so not online scanning for updates possibly!
  8. Posts : 525
    what version is your card? B? L? or SE?
  9. Posts : 13
    windows 7 32 bit
    that's my problem, because at first it stod only Marvell Yukon 88E8056 PCI-E Gigabit Ethernet Controller under network adapters. and then after searching around it seemed to me as if that was the device built inside my computer, my network card. and then i found this RTL8187_wireless under unknown device along with another device simply called "unknown device"..... then i right-clicked on RTL8187 > and then i clicked update drivers and i had to search manually for drivers as i had no internet. i did so and chose the driver i had downloaded on my laptop and transferred to my stationary it did not work.. so i tried again but this time i pressed : let me pick from a list of devices instead. and only found the SE type on the list under network adapters. so i clicked on it and got a update driver, saying it was not recommended because windows cannot verify that it is compatible with my hardwar. i clicked yes and got a bluescreen. then i restarted my pc and now the SE type was shown under the device manager>network adapters page. and when i troubleshoot my internet connection now it says that "Realtek RTL8187SE 802.11 b/g Wireless LAN PCIE network has a driver problem" but im not sure if that is my type as it only appeared after i had clicked on it... i think it is that named "unknown device" under the unknown device page, i don't think windows can identify my inernet receiver
  10. Posts : 525
    try this marvell driver for vista. if it doesnt install, try it again in compatibility mode.
    Marvell Yukon 88E8056 PCI-E Gigabit Ethernet Controller Driver Download - PC Pitstop Driver Library
