Laptop not using full power of my RAM?
  1. Posts : 14
    Windows 7 Home Premium 32
    I just posted another thread and got my answer there via the Nero Info Tool 5. This tool was awsome and it showed me something more that made me think:
    When I go to the window called "Hardware" it shows me my hardware specs and not everything adds up: It says that my RAM is at 2Gig but it should say 4Gig. What does this mean?
    Another thing: Same tool says that my graphic-card needs an update but when i go to update it, it says that it has the latest update.
  2. Posts : 289
    Please fill in your system specs, though I will also reply with my suspicions without those.
    Windows of any version in 32-bit will only address 4 GB of memory, max. You likely also have an integrated video card, which will use "shared" memory, taking memory from your RAM, decreasing the amount of memory available to the system.
  3. Posts : 240
    Win 8 RP, Win 7, XP
    You can try from an elevated command prompt:
    bcdedit /set PAE forceenable
    bcdedit /set IncreaseUserVa 4096
    reboot, see how much ram is reported.
  4. Posts : 14
    I think it is due to me running 32-bit windows. I read some threads and I think thats the problem.
    Thanks anyway
