Problem with PCI wireless card
sangamangi
9:36 PM
I have windows 7 ultimate x64 installed in one partition and I have windows 7 Home Premieum x86 in another partition. when i use my Ultimate x64 i can use the Belkin PCI wireless card. but when I load in the other windows x86, I cannot even see the Belkin PCI card in the device manager.
How do I get the PCI card to be recoginized by the device manager. Thanks
windows 7 Ultimate x64Intel core 2 QuadTranscend 4GBOnboard
Mine
Intel core 2 Quad
Intel DG45ID
Transcend 4GB
Onboard
Onboard
Samsung 21
1600x900
500GB sata, 500 GB sata
Coolermaster
Coolermaster
Coolermaster
2Mbps
This could be an issue with the drivers, Im sure you will have an X64 driver and a X86 driver for you Belkin PCI device.
I take it that you have installed the relevant drivers on both versions of 7.
7 would still detect the hardware in device manager, check the network adapters, or the other devices with the yellow question mark.
hope this helps.
7 ultimate x64Intel core i7 2600KVengeance™ — 16GB Triple Channel DDR3 PC16000GeForce GTX 560 Ti
CustomBuild001
7 ultimate x64
Intel core i7 2600K
ASUS P8Z68-V PRO
GeForce GTX 560 Ti
HannsG 22" widescreen (HDMI)
Samsung 1TB x2(RAID1) Deskstar 160G, Buffalo ExHD 500GB
Corsair 850HX
Antec Three Hundred Gaming Tower Case
CPU Freezer 7 Pro Rev. 2...ANTEC 3phase cooling, 2 intake.
microsoft intellitype 6000 v3.0
microsoft sidewinder
50Mb
64GB SSD in pipeline for Intel Smart Response Technology.
The thing is, the Pci card doesn't even show up in the device manager under network properties. whereas, i can see both the network adaptors running X64..
Mine
Intel core 2 Quad
Intel DG45ID
Transcend 4GB
Onboard
Onboard
Samsung 21
1600x900
Coolermaster
Coolermaster
Coolermaster
2Mbps
Goto device manager and select view, then can you take a screen shot of your device manager in X86 with the network devices and other devices extended.
Did you install two different drivers on both version of 7.
CustomBuild001
7 ultimate x64
Intel core i7 2600K
ASUS P8Z68-V PRO
GeForce GTX 560 Ti
Corsair 850HX
50Mb
when i boot with my normal windows 7 Ultimate x64, i can see both the devices in the device manager. Both the devices work fine.
But, when i boot with windows 7 Home Premium K ( Korean), i can see only the built in Giabit adapter and it works fine as well. I do also have the 32 bit driver for belkin PCI card.
what am I missing here? How do I go from here?
Mine
Intel core 2 Quad
Intel DG45ID
Transcend 4GB
Onboard
Onboard
Samsung 21
1600x900
Coolermaster
Coolermaster
Coolermaster
2Mbps
Did you install the X86 driver in windows 7 Home Premium K ( Korean)...
CustomBuild001
7 ultimate x64
Intel core i7 2600K
ASUS P8Z68-V PRO
GeForce GTX 560 Ti
Corsair 850HX
50Mb
Yes I did, but for no joy. I'll to uninstall and reinstall the drivers and see what happens. Thanks
Mine
Intel core 2 Quad
Intel DG45ID
Transcend 4GB
Onboard
Onboard
Samsung 21
1600x900
Coolermaster
Coolermaster
Coolermaster
2Mbps
finally sorted, I had to run the driver software from Belkin's site in XP compatible mode and now I can see the PCI card in the device manager... now off to get the right drivers in manually.... thaks a lot
Mine
Intel core 2 Quad
Intel DG45ID
Transcend 4GB
Onboard
Onboard
Samsung 21
1600x900
Coolermaster
Coolermaster
Coolermaster
2Mbps
Glad to be of assistance...
please feel free to leave rep using the middle icon at the top left of this post...:D
also you can end this thread as solved.
classic
CustomBuild001
7 ultimate x64
Intel core i7 2600K
ASUS P8Z68-V PRO
GeForce GTX 560 Ti
Corsair 850HX
50Mb
